A good machinist - what to expect?
https://slantsix.org/forum/viewtopic.php?t=52322
Page 1 of 2
Author:  Eatkinson [ Mon Jun 10, 2013 1:49 pm ]
Post subject:  A good machinist - what to expect?
A loaded question I know. Keep reading, this one's longer: I'm venting a little.
So far, the guy who's worked on my 225 block seems in line, despite general cantankerousity and the propensity to say "$ talks, B***SH*T walks". Whatever. But there's a few things irking me.
#1. Got back from two weeks away after he had my block, crank and cam. He'd tanked my cam, then he left it sitting out in the rain and it got rusty. "Oh, you were going to use that? (ya THINK? :!:) I thought you were getting a new cam. Well no matter, just wire-brush it, it will clean up ok." Well guy, why are you making more work for me?? The cam did clean up ok. But it took me a good one-two hours of polishing to do it.
#2. He tanked my block and other parts, and I got the block back to my work area. Looked good. He coated the exterior of the engine with a rust-colored metal coating to hold me over until I got it painted. No issue there. He also spray coated the inside of the block with a grayish paint or sealant. Looked Kosher to me. The other day, I was poking around in the block, and noticed some pockets that looked a little rough. Took a screwdriver and started scraping, and the gray sealant started scraping right off, with caked-on greasy engine grime underneath. Did more scraping, and found the he hadn't wire-brushed this (somewhat tucked-away) pocket corner of the inside of the block. Started to examine more, and found other pockets and areas that he hadn't fully cleaned before spray-sealing everything.
Started examining everything a lil' more carefully, and poked my finger into some of the oil gallery holes to check cleanliness. Photos below of my fingers showed you what I came away with.
If this were your project, your machinist, and you found this like I did, would this bother you or would you call this par for the course? I don't know whether this should be considered a problem, or if this is typical work (either the guy or his helper gets kinda lazy and figures this part of the engine doesn't really matter, so they don't poke into every corner and wire brush every single nook, and take a shortcut and just cover it). What do you think?
#3. Looked at his installation of my cam bearings, and noticed yesterday for the first time (grrrrr) that it seems the rear-most cam bearing is offset from the feed hole. There is passage clearance, but it's certainly NOT centered. About 1/2 the hole is blocked. Is this a problem? Do I need to take the block back to him and ask him to re-align this bearing for unrestricted flow? Or is that the way the cam bearings are? I don't remember the alignment of my original....
Thanks in advance for people's thoughts/comments.
Author:  64ragtop [ Mon Jun 10, 2013 9:41 pm ]
Seems to me that a calm discussion of these problem areas is called for. It's also an attitude check for him. If he's not willing to correct his mistakes, find another mechanic.
BC
Author:  Doctor Injector [ Mon Jun 10, 2013 10:55 pm ]
Not acceptable. Take it to him and tell him he needs to correct this now. He needs to hot tank the block and then install new cam bearings. If he gives you some line then tell him to refund the full amount. You might want to let us know what shop this is so we don't use them. Just my 2 cents.
Author:  SlantSteve [ Tue Jun 11, 2013 3:17 am ]
Just my thoughts here,but I think the cam should have had a regrind during the rebuild,it looks worn to me....should he leave it out in the weather? No,certainly not,but he probably considered worn and in need of replacement,personally,I wouldn't use it as is.
The block has been hot tanked,not cleaned for final assembly,crap in oil galleries and nooks and crannies are pretty typical,did you remove all the oil gallery plugs etc before you sent it to him? You certainly could have benefited from a more thorough cleaning,but with the normal pre assembly prep it would clean up fine,to me it looks like he has done a hot tank and initial wash prep,it's the builders job to clean it to his own standards.Even the most thorough machinist will tag a block stating its your responsibility to final clean/ prep the block.
I would inspect the location of the cam bearings with the cam installed,you may need to relieve the oil hole if the bearings locate correctly on the cam,but if not all he has to do is move it fore/ aft to align the oil hole. I would be keener to check his actual machine work,but all said and done I don't think he has done you any great favours,but unfortunately these days it's nothing new,it's just a job paid by the hour to him.
Author:  sandy in BC [ Wed Jun 12, 2013 7:39 pm ]
In my part of the world none of what you found is acceptable.
Add the incorrect bearing fiasco and it should be apparent you dont have a slant expert on your side.
That being said ....is there an alternative in your area?
I get all my stuff done at a "Chevvy" shop....this requires that Im the one who has to have all the answers....they just do the work......luckily they do it nicely.....even when they think Im insane to deck a block .100 or put chev valves in a slant head.
Author:  robertob [ Thu Jun 13, 2013 9:34 pm ]
I would not go back to him. Did he machine anything yet? I've NEVER had a machinist paint anything for me. The only reason he would do that is to hide something. That is crappy, sloppy work but it is unfortunately in line with what I have seen at many shops over the years.
You probably won't get any money back.
Depending on where you live I would say just take it to Mark Degroff at Cylinder Head Specialist in the valley. He is the finest machinist around. Or Hollywood Machine in Pasadena.
What shop did you use so that I know never to go there or recommend anyone go there?
Oh yeah and you should not be re-using that cam. It's a false economy. Once an engine is worn enough to need a rebore the cam should be replaced too. You can get it reground for $100 or less, and get some new lifters.
Author:  DusterIdiot [ Thu Jun 13, 2013 9:52 pm ]
Post subject:  Yep...
None of what I see is acceptable, neither of my machinists would put up with that kind of crap (and the parts are kept in the shop not out where it might get wet). When I get the parts back from the shop, I expect to take some time to rinse the machining oil residue off of it, clean any chips or left overs from machining in the bores and oil galley. I rechase the threads in the holes and usually get some gunk out of that too...
Those cam bearings should align with the hole, I've never had a set installed crooked like that...he's just lazy and rushing his work, it needs corrected.
Sorry to hear this is not a good learning experience (or maybe it is, but not the most inexpensive way).
x2 on getting your cam and lifters reground.
Author:  Eatkinson [ Fri Jun 14, 2013 1:12 am ]
Thanks for the feedback all. D.I, I've heard of getting your camshaft re-ground, but not re-ground lifters. Do you have to get new lifters with a re-ground cam, or does one actually get the lifters ground too?
Author:  robertob [ Fri Jun 14, 2013 6:49 am ]
You need either a new set of lifters or reground lifters with a new/reground cam. Most cam grinders also do lifters but if you can get a good deal on ebay, new ones are often the same price (roughly $4-$5 each).
Is this the same machinst that got you the wrong main bearings??
You really need to go somewhere else.
Author:  Eatkinson [ Fri Jun 14, 2013 10:56 am ]
I'm not planning on using the same machinist for anything else, but I'm trying to get them to close me out correctly. VAP engines in Sun Valley.
Author:  75valiant [ Fri Jun 14, 2013 11:28 am ]
wow! my cousins grew up in sun valley, which no one seems to have ever heard of.
sorry to hear about your experience. hope he makes it right. remember, you get more flies with honey than vinegar. if he thinks he has already lost your business forever, he is unlikely to try to make you happy.
Author:  robertob [ Sat Jun 15, 2013 12:57 am ]
Bummer, good luck with that. If you get stuck take it to Mark Degroff, he's the best.
Author:  olafla [ Sat Jun 15, 2013 2:46 pm ]
Eatkinson, I am sorry you had to find out the hard way, unfortunately pride and workmanship don't go hand in hand anymore.
I am not a customer there myself, but there is a company close to you that has been around since 1915, and probably still has machinists with intimate knowledge of the SL6, the Egge Machine Company. The may not be the cheapest, but they have an excellent reputation. They also stock cams and lifters for the SL6.
Olaf.
Author:  Eatkinson [ Sat Jun 15, 2013 5:57 pm ]
Thanks olafla. Egge reproduces Packard pistons. I was aware of them, but didn't think to go to them for SL6 parts. Appreciate the lead.
Author:  Eatkinson [ Sat Jun 15, 2013 6:11 pm ]
Post subject:  Re: Yep...
Hey DI, and robertob, you both are telling me to go get my stock cam re-ground and new or reground lifters. If I use the cam as-is (what I was planning to do), what happens?
Yes, the cam looks worn, but once I go get it ground, I will most likely need to have a different machinist (definitely not the first guy I used) yank these new cam bearings that were just installed, and install a set of correctly-oversized cam bearings, yes? So I've just wasted $ on having these new bearings installed if I get the cam re-ground.
Thoughts?
Page 1 of 2 All times are UTC-08:00
