It is currently Mon Nov 30, 2026 7:07 am
 Post subject: Oil Pan install
PostPosted: Tue Jun 11, 2013 5:18 pm
Okay I am an idiot I looked at the oil pan off my other engine and it looked good for my engine bay but then we found a hole and I pulled the pan off my parts engine and used that. Doh!!! wrong oil pan of course I did not realize that till after I painted it AND had the engine all the way in the bay.
So now my question is should I use a sealer RTV or something on the gasket? Will I need a new set of gaskets?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Wed Jun 12, 2013 7:18 pm
We're all idiots, but we're slant six idiots!
Home -> Articles -> Main Seal Installation and Oil Pan Sealing, by Doc
Olaf
Aspenized
PostPosted: Wed Jun 12, 2013 7:46 pm
Muchas Gracias I did ended up finding that article.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jun 13, 2013 8:10 am
Okay so I have a question. As we know my oil pan had to be swapped but I had already poured 4 quarts of oil and the break-in oil into the engine. My question is I lost about 1/2-3/4 of a quart maybe more. Do I need should I add another bottle of break-in? Would it be safe for me to either way?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jun 13, 2013 8:13 am
If all the pushrods are spinning... Run it!
PostPosted: Thu Jun 13, 2013 8:20 am
Doc I don't understand. Do you mean don't worry about it?
As a side not I have turned the engine over with the bad pan probably a dozen times or more.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jun 13, 2013 9:32 am
Yes...
Don't worry about it...
Time to get it started but be sure you have oil pressure & all the pushrods are spinning, once it starts.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
