| Oil Pan install https://slantsix.org/forum/viewtopic.php?t=52339 |
| Author: | jhdeval [ Tue Jun 11, 2013 5:18 pm ] |
| Post subject: | Oil Pan install |
Okay I am an idiot I looked at the oil pan off my other engine and it looked good for my engine bay but then we found a hole and I pulled the pan off my parts engine and used that. Doh!!! wrong oil pan of course I did not realize that till after I painted it AND had the engine all the way in the bay. So now my question is should I use a sealer RTV or something on the gasket? Will I need a new set of gaskets? |
| Author: | olafla [ Wed Jun 12, 2013 7:18 pm ] |
We're all idiots, but we're slant six idiots! Home -> Articles -> Main Seal Installation and Oil Pan Sealing, by Doc Olaf |
| Author: | jhdeval [ Wed Jun 12, 2013 7:46 pm ] |
Muchas Gracias I did ended up finding that article. |
| Author: | jhdeval [ Thu Jun 13, 2013 8:10 am ] |
Okay so I have a question. As we know my oil pan had to be swapped but I had already poured 4 quarts of oil and the break-in oil into the engine. My question is I lost about 1/2-3/4 of a quart maybe more. Do I need should I add another bottle of break-in? Would it be safe for me to either way? |
| Author: | Doc [ Thu Jun 13, 2013 8:13 am ] |
If all the pushrods are spinning... Run it! DD |
| Author: | jhdeval [ Thu Jun 13, 2013 8:20 am ] |
Doc I don't understand. Do you mean don't worry about it? As a side not I have turned the engine over with the bad pan probably a dozen times or more. |
| Author: | Doc [ Thu Jun 13, 2013 9:32 am ] |
Yes... Don't worry about it... Time to get it started but be sure you have oil pressure & all the pushrods are spinning, once it starts. DD |
