It is currently Mon Nov 30, 2026 12:33 am
 Post subject: Pistons
PostPosted: Fri Jun 14, 2013 12:54 pm
What piston came from factory in the 225? Does anyone have a factory piston?
PostPosted: Fri Jun 14, 2013 1:05 pm
I meant a picture of it.
PostPosted: Fri Jun 14, 2013 2:15 pm
The factory used a cast piston with steel expansion "struts" casted into the pin boss area.
3.400 diameter, .901 pin bore size, 1.76 compression height.
