| What did I get? e-Distributor https://slantsix.org/forum/viewtopic.php?t=52351 |
| Author: | DusterIdiot [ Wed Jun 12, 2013 7:17 pm ] |
| Post subject: | You got screwed... |
That's a V-8 EI distributor and is not compatible with our engine at this time. The tag would have been stamped 3874876 not 4091902, the part number suggests it about a 1979 (whether the distributor is actually a 4091902 can be up for debate). Time to get the right one from the vendor, or get a full refund plus return shipping, it's not even close for your application. -D.Idiot |
| Author: | DusterIdiot [ Wed Jun 12, 2013 7:32 pm ] |
| Post subject: | Holy shoot... |
http://www.ebay.com/itm/MOPAR-318-225-E ... e6&vxp=mtr Man, this is why it pays to be a walking parts catalog. The above URL blatantly lists the part number, the tag on the distributor doesn't even match! And he has it listed for a 318 as well (that gear ain't gonna work!) The part number corresponds to a 225 distributor for canada only 1 barrel cars, looks like the governor is a 13R so not a desired candidate. http://www.ebay.com/itm/Slant-Six-Elect ... b2&vxp=mtr These look nice, too bad he didn't list the tag number for a quick sale and better pricing, if they are 'desireable'. Let me know how your return goes...hopefully he honors it and doesn't try to goof you out of your dough. -D.idiot |
| Author: | Eatkinson [ Thu Jun 13, 2013 12:41 am ] |
Thanks D.I. Yes, I'll let you know how it turns out. Any potential issue using my Standard Bluestreak CH-410X distributor cap with the extended tip rotor on this e-Distributor (the right one which I'll get from the seller)? |
| Author: | DusterIdiot [ Thu Jun 13, 2013 7:14 am ] |
| Post subject: | Nope.. |
You shouldn't have a problem with that combination, though I would "wiggle" the shaft and see if it has any give to it. If the shaft/bushings are really worn then the extended tip can contact the cap contacts and well... -D.Idiot |
