It is currently Mon Nov 30, 2026 3:04 am
 Post subject: rocker shaft shims
PostPosted: Wed Jun 12, 2013 4:43 am
I tried doing a search for these but no luck, does anyone make some preshaped or would I be better off trying to make my own.
 Post subject: Good Luck...
PostPosted: Wed Jun 12, 2013 7:24 am
It's better to get the proper pushrods than shim the rockers. Posts from the past have shown that a majority of people doing shims have cracked the shaft cradles.
-D.idiot
PostPosted: Thu Jun 13, 2013 8:57 pm
Any advice on shops or how to formulate the correct length. Thanks. dean
 Post subject: Pushrods...
PostPosted: Thu Jun 13, 2013 9:41 pm
http://www.pushrods.net/
Best way to do it is make an adjustable pushrod: take a stock push rod, cut a 1/2-3/4" chunk out of it about 2-3" down from the "cup". Use a threading die and thread the hollow part of the rod for 1/4" NC, go to your local home depot or lowes and get a small chunk of 1/4" all thread and 2 nuts for jamb nuts. (Doc used to have a good pic of his adjustable pushrod, but I can't find it.)
Adjust the rod so that your rocker arm adjuster has a few threads under and over the rocker, lock the nuts, check the valve springs for coil binding, then mail the pushrod to smith brothers above asking for 12 that length, they will get back to you on price and you are good to go from there.
PostPosted: Fri Jun 14, 2013 4:37 pm
im going to work on it this weekend. Thank you sir
PostPosted: Fri Jun 14, 2013 6:44 pm
what valves are you using? usually only longer valves will need shims.
Users browsing this forum: Google [Bot] and 7 guests
