It is currently Sun Nov 29, 2026 11:22 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page 1 2 3 4 Next
 Post subject: new carb issue.
PostPosted: Sat May 04, 2013 10:21 am
I picked up another carter bbs, that is correct for 65 225. It runs right off the bat better then my previous carb. I cleaned it out very well, went through it with new gaskets, diaphram, needle and seat. Even had shaft bore rebushed.
In order to get it to get highest and best running vacuum setting. Mixture screw needs to be out 4 full turns, which makes it feel a bit too loose. Vacuum gauge bounces around a very tid bit. Only intake leak I can find is if I spray carb spray directly into the throttle shaft. And in my experience, every new carb with new shaft bores will suck in a very little bit of air.
If I rev it up slowly you can feel it kinda miss and sputter, high rpm seems to be ok.
Also if sitting idling for a bit. It will randomly feel and sound like it falls off another notch off thr staircase cam but its already on the main idle screw. And while that happens, the vacuum gauge will read 19, then fall to 15ish and bounce around like crazy.
The only gasket I didn't replace is the mainjet one. I didn't have an extra one in my box of parts and stuff. Dont see it being my problem though?
PostPosted: Sun May 05, 2013 8:46 am
Any ideas?
PostPosted: Sun May 05, 2013 9:42 pm
How sure are you that your valve adjustment is good? I ask because your vac gauge shouldn't bounce at all. That usually indicates some form of valve sealing problem. An engine is an air pump- if you pull a plug wire off or have a vacuum leak cause a misfire, the engine should still suck, compress, & exhaust air- the vac reading might be lower than normal, but it should stay steady. If it gets worse after the engine runs awhile then I hope that it is because a valve rocker is a bit too tight. Otherwise it might be a valve stem sticking in its guide, a valve/seat problem (or possibly a broken valve spring).
63 Valiant Wagon
225 - 4 bbl
PostPosted: Tue May 07, 2013 3:58 am
For testing you can block off the idle air bleed.
PostPosted: Tue May 07, 2013 8:39 am
Valves are not the issue. And what's this airbleed your talking of? I must have some sort of intake leak somehwere I suppose. Definitely not at the manifold. Like I said the only spot I found was spraying directly into the shaft
PostPosted: Tue May 07, 2013 9:23 am
This sounds almost exactly what I am experiencing with mine. Are your rpms fluctuating at idle like how your vacuum is?
1978 4 door Dodge Aspen, Super Six
PostPosted: Tue May 07, 2013 5:16 pm
Not what I can tell by ear, my vintage tack broke :(
PostPosted: Tue May 07, 2013 7:17 pm
ah, mine I noticeable by ear. I've got one of those snazzy timing guns with a read out on it that I use to dial it in.
PostPosted: Tue May 07, 2013 7:54 pm
http://u225.torque.net/cars/SL6/docs/Ca ... Manual.pdf Page 2 Low -speed circuit shows idle air bleed. I do not have a bbs carb or any pictures. For example my 1920 holley needs work,lean idle. So for testing and tempary repair, took wire about half the size of the air bleed and stuck it in the air bleed.Less air changes the air fuel ratio makes it richer. Tried different wire sizes till i found the right one.
PostPosted: Tue May 07, 2013 8:11 pm
http://www.slantsix.org/forum/viewtopic ... w=previous Idle air bleed location
PostPosted: Wed May 08, 2013 12:53 am
So what would be a permanent fix and why would that airbleed need work for a carb ment on that engine.
PostPosted: Wed May 08, 2013 3:45 am
http://www.arb.ca.gov/fuels/gasoline/gasoline.htm#reg
PostPosted: Wed May 08, 2013 3:47 am
http://www.arb.ca.gov/fuels/gasoline/faq.htm Engine same gas is different
PostPosted: Thu May 09, 2013 5:19 pm
Hi kielbasa, take a look at this animated version on how to interpret different vacuum gauge readings, you may recognize your meters pattern: (some of the clickable green buttons have a two-stage response)
How to Use and Interpret a Vacuum Gauge
Olaf
Aspenized
PostPosted: Thu May 09, 2013 6:24 pm
Looking at my old carter spec sheets.Years 64,65,66. Idle restriction [economizer] always .052. Idle air bleed size .0629 for all 225 .061 for 170. Idle jet size varied .028 .0295 .0315 .033.
