It is currently Sun Nov 29, 2026 4:40 am
 Post subject: Rocker Arm Assembly
PostPosted: Tue Jun 18, 2013 1:03 pm
Can I reuse my mechanical rocker arm assembly? If so, how can I clean this?
PostPosted: Tue Jun 18, 2013 1:25 pm
I cleaned mine with with carb cleaner, making sure to squirt cleaner through the passages in the rocker arms. If there is hardly any oil flow you'd be better off getting them hot tanked.
When installing the rocker arm shaft, make sure to orient it correctly to line up the oil holes with the passages in the rocker arms.
This article may help and it shows how to orient the shaft as well.
SlantSixDan's reply in this thread also has good info whether or not you should replace, clean or hot tank your assembly.
1978 4 door Dodge Aspen, Super Six
 Post subject: Easy...
PostPosted: Tue Jun 18, 2013 1:29 pm
Take the rockers off and string them on a heavy wire like a necklace with the spacers and hold down washers. Then give them and the shaft to your machinist to hot tank and they will come back pretty clean...then all you have to do run a small wire through the oil passages to clean any build up out of it and you're good to go. My machinists charge a flat rate for cleaning, so when doing a rebuild I give him a 5 gallon bucket with the alternator brackets, valve cover, oil pan, etc....it then comes back very clean after either a hot tank or a scalding pressure washing then all I have to do is prime and paint then reassemble. Technically your machinist is already charging you to clean the block and head for machining so a few extra parts are going to be too much of a hassle to hose down with your
rods.
PostPosted: Tue Jun 18, 2013 1:37 pm
Ok thanks!
PostPosted: Thu Jun 20, 2013 6:16 pm
+1 to using carb cleaner. Since I have quite a few /6's, I usually take the best ones and use those (if I know mileage, etc) or use the ones showing the least amount of wear.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
 Post subject: one further...
PostPosted: Thu Jun 20, 2013 6:21 pm
I actually take them and check the length with a caliper and segregate them into groups so I can get a uniform set of these for uniform lift across the engine. (In one case the exhaust lobes on the cam were shy about .006 so I installed the slightly longer rockers on the exhaust side compared to the intake to even it out some). It's just tough to get a cam and know that the profile is set for a 1.5 lift and the stock rockers are closer to 1.465.... :roll:
