Holley 2300 Troubleshooting
https://slantsix.org/forum/viewtopic.php?t=52389
Page 1 of 3
Author:  73Sam [ Sun Jun 16, 2013 5:37 pm ]
Post subject:  Holley 2300 Troubleshooting
Im proud to say that im finishing up my current Duster project (super six intake, dutra duals, holley 2300) and it should be cruise-ready this week. My only stages left are carb adjusting and getting my exhaust installed.
I just hooked up my lokar cables today and was fiddling with the carb throttle A LOT in the process. Though i had tested the carb when i first started it and everything was fine, the throttle wasnt being played with like it was today. However, upon startup today, i was greeted with a little flame in the carburetor. Its a holley 2300 350 CFM. I am pretty sure that it was caused from the combination of the carburetor being both untuned and flooded, but i would like to hear any feedback you guys might have. I was going to adjust the carb today, but i dont want to mess with it until i have a straight forward idea as to why that occurred. I started the engine 3 or 4 times before without any fire, but today i got a little flame after toying with the throttle.
Author:  DadTruck [ Sun Jun 16, 2013 5:55 pm ]
when the engine is being turned over with the starter,, it is spinning quite slow when compared to normal engine operating rpm's. Consequently it does not take much for an intake valve to momentarily hang open, and then when the spark plug does its thing,, there is a direct path back to the carb. Same thing on the exhaust,, then you get a backfire through the tail pipe.
The cranking rpms probably also aggravate any slop in the timing chain.
That is good reason to be careful when working around an open carb, keep your fingers and face away and a fire extinguisher handy
Author:  73Sam [ Sun Jun 16, 2013 7:37 pm ]
So are you saying that the normal spark ignited the flooded carburetor?
Author:  DusterIdiot [ Sun Jun 16, 2013 7:40 pm ]
Post subject:  Yep...
That's typical if your timing chain is a little sloppy. Just curious what is your distributor/timing set to at idle?
I wear safety glasses, I like my eyebrows too much... :wink:
The manifold is flooded with liquid gas not the carb, one backfire and it gets ugly.
Author:  73Sam [ Sun Jun 16, 2013 8:13 pm ]
Not sure, i havent picked up a light yet. Clearly, that should have been higher up on my priorities. I heard many people say that the timing being slightly off could cause the backfire.
Edit
The timing has never been messed with.
Author:  73Sam [ Mon Jun 17, 2013 2:36 pm ]
I just picked up a timing light. quick little question regarding that; how am I supposed to use it if my Carb breathes fire when I turn it on? :?:
Author:  Reed [ Mon Jun 17, 2013 3:02 pm ]
If the motor doesn't run and backfires through the carburetor then you will need to retime the motor manually before you can use the timing light. Pull the valve cover and turn the crankshaft by hand while you watch the movement of the valves on the #1 cylinder. Rotate the crankshaft in a clockwise rotation until the intake valve on the #1 piston opens and closes. After the #1 intake valve closes, keep rotating the crankshaft until the timing mark is a TDC on the timing tab. Now pop the distributor cap off and see if the rotor is pointed roughly under the #1 spark plug tower. If it isn't, adjust it so it is. If it is, then you either have a non-timing related issue or a gross misalignment of the camshaft to the crankshaft.
Author:  73Sam [ Mon Jun 17, 2013 7:06 pm ]
alright, Ill do that tomorrow. is that a normal occurrence when you upgrade to a larger carburetor with a higher CFM rating? this didn't happen when I had my stock 1-bbl on there.
Author:  DusterIdiot [ Mon Jun 17, 2013 7:27 pm ]
Post subject:  No but...
No, but it could exacerbate a timing issue if there was a vacuum leak because of the adapters. The new carb will let in more air with less throttle plate opening than the smaller carb.
Per Reed, check the distributor indexing first, then we can go from there.
One question I have is: is the vacc. advance hose connected to the nipple on the side of fuel block, and do you have the nipple under the fuel bowl at the base of the carb plugged or attached to a vacuum gauge?
Author:  73Sam [ Mon Jun 17, 2013 7:51 pm ]
Post subject:  Re: No but...
the nipple under the fuel bowl is attached to the line going to the front crankcase breather. the vacuum advance hose is connected to the nipple on the side of the carburetor facing the valve cover.
Author:  73Sam [ Tue Jun 18, 2013 9:19 am ]
I'm going to throw in another detail- I blocked off my EGR valve. with a block-off plate. the carburetor also only had 3 of the 4 bolts mounting it down. lastly, I have not hooked up the choke yet. however, these were all still true the first time I started it without sparking a flame.
ALSO
just took off the valve cover. what do you fellas find to be the best way to manually turn the crankshaft on this particular engine? will it turn by hand if I take the spark plugs out? do I need a bolt or breaker bar to turn the pulley?
Author:  DusterIdiot [ Tue Jun 18, 2013 9:45 am ]
Post subject:  Hmmm...
No problem there.
That is not good, this needs to be fixed before anything else happens.
That will need to be addressed, your hollay has the electric choke, correct? If so you can run the choke thermostat wire previously used on your 1 barrel set up to the + prong on the choke housing, then run the ground to a bolt on the head near the valve cover (where the throttle spring bracket for the 1 barrel used to be).
Typically the old/stock way was to remove the plugs put in neutral put some tension on the fan belt with one hand and roll the fan whichever way it needs to go...the upgrade way would be to go to a fastener place and get a 3/4 NF bolt about 1 1/2" long with a washer and thread it into the crank snout and use a large wrench to do the turning.
I will take that to mean that your carb does not have the 3/8" PCV line and your are using the 1/8" port with adaptor as the PCV port...?
Just for peace of mind, what is the holley part number off the air horn? (0-7448? or?)
Author:  73Sam [ Tue Jun 18, 2013 10:13 am ]
Post subject:  Re: Hmmm...
I just put the 4th bolt on it. the model is the 7448. It has a manual choke so I Will have to run a cable.
the port located at the top of this picture is going to the crankcase breather.
Author:  Reed [ Tue Jun 18, 2013 10:19 am ]
It is very likely you are encountering a lean backfire due to vacuum leaks. The port at the top of your picture is the PCV valve port. The breather hooks to your air cleaner housing. Trying to start the motor with no choke will make it run very poorly, if at all, and it will be running comparatively lean to what it should be running at.
Author:  73Sam [ Tue Jun 18, 2013 10:34 am ]
I stated that wrong. my carb goes to my PCV. the breather at towards the rear of the valve cover isn't connected to anything because my new intake-style air cleaner does not have a port for it.
Page 1 of 3 All times are UTC-08:00
