| Engine rebuild clearance question https://slantsix.org/forum/viewtopic.php?t=52400 |
Page 1 of 2 |
| Author: | hideogumperjr [ Mon Jun 17, 2013 5:53 pm ] |
| Post subject: | Engine rebuild clearance question |
Hi folks. I just got my block and crank back from the machine shop last week. I cleaned up the block and checked crank clearance and monkeyed around with the timing chain setup (Thanks Reed!.) Block was bored to .030" and rings are .030". I decided to check the ring gap so I dropped a ring into the cylinder and ran it down a couple of inches and ended up with what looks like an astronomical amount of gap. My FSM says .010" to .020" but I ended up with about 3mm or .118". I was able to put seven feeler blades into the gap and instead of adding them all up I used the micrometer to measure the blades as it was easier to read the metric side of things. I also slipped a piston into the bore and it seemed pretty loose in it. I was able to slide a .018" gauge down beside the piston at the top of the cylinder. I am going to pick up the head tomorrow and I think I need to find out what's up with these clearances and get it straightened out. Any thoughts on what I am missing? Thanks again to all the great guys and help here! John Pictures below: Top compression ring Top with feeler gauge All the feeler blades used to measure Side view of all the gauges Second compression ring |
| Author: | DadTruck [ Mon Jun 17, 2013 6:42 pm ] |
sounds like you either got the wrong (standard size ?) pistons and rings or the shop bored the cylinders too large. do you have a set of calipers to check the bore diameter,? Would not be as accurate as a dial bore gauge, but would be close enough to tell you if the bore size was the problem or not.. |
| Author: | DusterIdiot [ Mon Jun 17, 2013 7:21 pm ] |
| Post subject: | Yikes! |
Quote: do you have a set of calipers to check the bore diameter,? Would not be as accurate as a dial bore gauge, but would be close enough to tell you if the bore size was the problem or not..
Definitely worth looking at, I even check the bores with an inside gauge before checking the rings and piston skirts just to make sure my block didn't have a surprise.If it does come to that, I think I still have a set of .040 pistons Kidd sold me and a set of rings for them in a pinch (.040 is getting to be a tough one to get from Fed Mog now a days, most times suppliers have the pistons but no rings...). -D.Idiot |
| Author: | hideogumperjr [ Mon Jun 17, 2013 7:24 pm ] |
all I have is a micrometer. Want to see if I can get a loaner in the area. I checked the ring box and it says .030. Think Ill get all the info from the boxes and post but 'sposed to be .030 over. Thanks for the reply. |
| Author: | DusterIdiot [ Mon Jun 17, 2013 7:31 pm ] |
| Post subject: | I'd go... |
Quote: I checked the ring box and it says .030.
It's all there, if the boxes are .030 over. You should get a set of Harbor Freight inside gauges (hopefully you have a 3"-4" micrometer for this, at the moment it's damage control to see if it's 3.43 or 3.44...just a rough estimate to see if the machinist went too far.)-D.Idiot |
| Author: | hideogumperjr [ Mon Jun 17, 2013 7:51 pm ] |
Thanks D. |
| Author: | hideogumperjr [ Mon Jun 17, 2013 8:36 pm ] |
As best as I can tell with my micrometer and only at the top of the cylinder I get a measurement of around 3.45". Wish I could be more precise but does not appear to be 3.43" as it should be. Piston is around 3.41" again with my micrometer. I should check them all for comparison tomorrow before going to the machine shop. :=( |
| Author: | DusterIdiot [ Mon Jun 17, 2013 9:27 pm ] |
| Post subject: | How about? |
Quote: Piston is around 3.41" again with my micrometer.
What is the measurement be across the skirt under the wrist pin about 1/2" up from the bottom edge of the skirt wit your mic?-D.Idiot |
| Author: | hideogumperjr [ Mon Jun 17, 2013 9:45 pm ] |
Unfortunately my micrometer does not have wide enough jaws to get the measurement that far into the piston. |
| Author: | SlantSteve [ Mon Jun 17, 2013 10:04 pm ] |
You have both pistons and rings marked .030" oversize and they both give you indications of excessive clearance,sounds like the bore is too big for .030".....best to take it all back to him when you pick up the head and get him to check.You may end up being .060" oversize |
| Author: | DusterIdiot [ Mon Jun 17, 2013 10:14 pm ] |
| Post subject: | Geometry |
Quote: You may end up being .060" oversize
Just as a simple exercise of geometry...circumference of a 3.43 bore is 10.776"...add .118...then divide by Pi = 3.467" (little fudge room for rounding and measuring point of bore taper) I think Steve hit it on the head being .060 over.-D.Idiot |
| Author: | Dart270 [ Tue Jun 18, 2013 3:10 am ] |
If you did not give your pistons to the shop to have them use those to fit to the bores, then it is time to find another machinist (after they fix this @#$% up). Lou |
| Author: | mattelderca [ Tue Jun 18, 2013 4:21 am ] |
Sounds like the engine was already "30 over" and the machinist was told to "make it 30 over" so he did. The machinist should always have the pistons and rings in hand before boring and honing. Did he? |
| Author: | Dart270 [ Tue Jun 18, 2013 7:50 am ] |
Yes, if the machinist did not ask for them beforehand, he is not a dependable machinist. Lou |
| Author: | hideogumperjr [ Tue Jun 18, 2013 8:55 am ] |
I have reservations for sure on the machinist. Worried about it most of the night and that sucks. Bad enough getting sleep as it is at my age. I did not specify a bore only asked to have it checked and bored to make it good. The block was so grunged up from hard black carbon oily deposits I just had him go through it and do what needed to be done. He ordered pistons and rings and what I needed. Ill be talking to them this AM. I have to think I have to tear down what I have assembled but it seems like it is the only solution to my problem right now so as to make it right. Thanks yall. |
| Page 1 of 2 | All times are UTC-08:00 |
