It is currently Sun Nov 29, 2026 9:03 am
PostPosted: Mon Jun 17, 2013 8:32 am
All -
the trucks previous owner replaced the down-pipe from the manifold with a '81 version without the mini cat, cut the pip for the smog pump and crimped it shut.
I had to replace the down-pipe with a new Walker 44958 but need advice how to plug the smog pump attachment hole. What size threads are they or do you have any ideas how to plug it?
Tad
86 D-100 "The Raccoon"
PostPosted: Tue Jun 18, 2013 12:35 am
It didnt come up in d100 exhaust but a search for "d150 exhaust" turned up the old post.
http://www.slantsix.org/forum/viewtopic ... 50+exhaust
There are a few others on here as well that mainly deal with the D150, but search out both types, there are plenty of threads to help with most all of your questions.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Wed Jun 19, 2013 7:18 am
That was there for a O2 sensor, I would try a spark plug.
85 d-100 HEI 2BBl
06 Toyota Corrola
Users browsing this forum: Google [Bot] and 19 guests
