It is currently Sun Nov 29, 2026 3:38 am
PostPosted: Sun Jun 16, 2013 3:29 pm
Car Model: 1963 Dodge Dart convertible
Hi folks. Doing my rebuild and I have read lots of threads and DDs guide sticky for seal replacement.
One thing I seem to be confused on is the seal orientation. The stickey says: The lip type main seal is directional and must be installed in it's groove so the flat side of the lip is facing to the inside of the engine. The angled or sloped side faces outward.
I get this understanding but wanted to be sure I got it right as I don't want an oil leak.
I always thought that the lip was pointed in towards the engine to allow oil to fill the gap behind the lip with oil and create some pressure to hold the edge riding on the crank (or flywheel or whatever) secure and keep the oil in. I reason that if the lip is placed outward then the oil pressure can push past the lip.
Can you learned people rest my frantic mind with the correct understanding for rear seal replacement?
Thanks
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Sun Jun 16, 2013 3:32 pm
Your logic sounds pretty reasonable to me. I never really thought about it when I did mine...just put it in the way I was instructed to in the article on here.
Your thinking seems sound to me, but ill let one of the other guys chime in.
PostPosted: Sun Jun 16, 2013 4:18 pm
So after rereading the sticky a few times more and writing the post and going back outside and looking at the seal a few times and drinking a cup of coffee, it seems like I was looking at both sides differently and now it seems more clear.
The flat side Doug refers to does indeed seem to be the lipped side of the seal that would put the lip pointing in towards the interior.
John
PostPosted: Sun Jun 16, 2013 4:31 pm
Oh okay. I see where you were confused. Glad you got it now.
PostPosted: Sun Jun 16, 2013 5:28 pm
Thanks man!
PostPosted: Sun Jun 16, 2013 9:32 pm
"3 Deuce Webber" is part of the system used to denote how many posts you've made. You start out as "1 bbl" & it changes as you make more posts. Eventually you'll make "TBI slant 6", "EFI slant 6" turbocharged, supercharged, etc.
It has nothing to do with your actual car :wink:
63 Valiant Wagon
225 - 4 bbl
 Post subject: Rope Seal?
PostPosted: Thu Jun 20, 2013 11:23 am
OK, I'm going to the rear seal change soon, so I have a question as well.
Rope seal? I've heard varying stories on this, Doc told me once that after crank and bearing surfaces are machined, one might do better with a rope seal as it conforms better to create a better seal.
I can tell you, after recently having my slant rebuilt, that I do indeed have a rear seal leak. I'm not sure if the shop put the seal in correctly as Doc instructs, I'll check when the engine is pulled...but, I have a couple rope seals, and I'm wondering if I shouldn't just try that this time.
I'm sure rope seals can be done incorrectly and be too tight, but anyone have experience with installation and performance over time of the rope seals?
thanks,
BG
PostPosted: Thu Jun 20, 2013 12:21 pm
Thanks Wagon was bugging heck out me! Sig has been changed!
PostPosted: Thu Jun 20, 2013 12:23 pm
Sounds like a good question 67. I hope I have no oil leaks. Getting to dang old to pull engines and thinking about doing it on the ground hurts even worse!
Anyone have any data on rope vs hard rubber?
PostPosted: Thu Jun 20, 2013 2:03 pm
See the bottom of page 2 on the "Twiggy" engine build thread for "rope vs rubber" mainseal info.
http://www.slantsix.org/forum/viewtopic ... c&start=15
PostPosted: Thu Jun 20, 2013 9:59 pm
Thanks Doc. I have read that thread a couple of times but because there is so much information there that I get kind of thread-shocked in reading.
Funny thing was when you pointed it out specifically it was like I had missed that part or something.
I really like reading the stuff and going oh yeah great idea!
Cheers yall.
 Post subject: rope seal tutorial
PostPosted: Thu Jun 20, 2013 10:13 pm
Yes, thanks so much Doc, that clears it up very well.
BG
