| oil pump failure? https://slantsix.org/forum/viewtopic.php?t=52411 |
Page 1 of 2 |
| Author: | '67 Dart 270 [ Wed Jun 19, 2013 11:54 am ] |
| Post subject: | oil pump failure? |
I was driving my (very well running) Dart home yesterday down the highway, happy as a clam, and without warning, I heard a loud "bang!" then quick deceleration as I pulled off the highway, then another equally loud "bang" just before she quit. Ugh, my heart sank as I assumed it was a connecting rod failure or something...then I remembered that I've never seen a slant six catastrophically fail, they are bulletproof for the most part. I have to tell you, that bang was awfully loud, I was sure I'd see a connecting rod or part of my cam or crank hanging out of the block. There weren't any grinding noises or anything, just the two loud bangs and that was it. Anyway, I open the hood and I see fresh oil around the oil pump. I don't see any holes in the block, and she still turns over smoothly just won't start. I don't hear any grinding or weird noises (doesn't the distributor gear also run from the same cam gear?). I didn't try long, just a few seconds. Was the first bang the oil pump and the second the distributor gear/shaft? If it were the camshaft I'd here some odd noises when it turns over, no? I suppose the cam gear could be all chewed up... I read today on the forum some older posts about getting a hardened oil pump gear and that aftermarket oil pumps have failure issues? Was I a fool (rhetorical question) and overlook this weak link during the rebuild? Ugh again, she was running so well... I haven't done any diagnostics, but assuming it's my oil pump, does that necessarily mean I have to pull the engine, and is it likely the cam is damaged as well? Likely tore up the distributor gear too I suppose... This happened to anyone, same symptoms? I'm sure it's best to pull the engine no matter what (and that'll give me the chance to change that pesky rear seal), but can I pull the oil pump with the engine still in it's nest to assess the damage? Thanks all, having a bad day, give me some hope if you can... BG |
| Author: | Reed [ Wed Jun 19, 2013 12:04 pm ] |
I would pull the distributor and check the condition of the distributor drive gear and see if you can get an eye on the cam gear and oil pump gear through the distributor hole. |
| Author: | Fopar [ Wed Jun 19, 2013 12:09 pm ] |
I just looked at my spare engine, you can see the cam gear but not much of the oil pump gear (just the sides). Richard |
| Author: | Reed [ Wed Jun 19, 2013 12:11 pm ] |
Still, obvious damage to the cam gear would likely be visible, and he may get lucky and just have a blown apart distributor drive gear. I would pull the distributor before pulling the engine. |
| Author: | '67 Dart 270 [ Wed Jun 19, 2013 3:51 pm ] |
| Post subject: | thanks |
Yes, I'll definitely pull the distributor first, see what I can see. No matter, it seems like I have to pull the engine to assess the damage, collect fragments (e.g. if the gear or gears are broken/badly worn, find fragments). What are the chances this stayed relatively localized, i.e. the cam and other parts are OK, the chunks fell harmlessly into the pan and/or got stuck in the sump or filter (I have a strong magnet on the filter to catch stuff, not on the pan though..). I didn't hear any grinding or weird scraping noises at all after the two bangs...maybe I got lucky? If the oil pump is the issue and it stayed localized, perhaps I can pull the engine, clean out the fragments, reinstall new oil pump. What is the most bulletproof pump to use? I believe I read that someone on this board supplies heat treated gears for oil pump? Is there an aftermarket pump comparable to the old stock unit's durability? I didn't keep my old stock pump from the rebuild....ugh. Any suggestions? Any external oil pumps that replace the original setup so I don't have to worry about this again? Thanks all, my stomach has settled a bit, I felt absolutely sick when I heard that awful noise, my slant only has 6k miles on it. I should have researched a bit deeper on the board before installing that aftermarket oil pump. It just never crossed my mind that such a thing would catastrophically fail, as I've not dealt with aftermarket pumps before and I've never seen a slant six internal component fail. I did have a valve retainer fail and a valve got sucked into the cylinder of a 340 during a test run once, twisted it like a pretzel, but did not puncture the piston amazingly. That valve hangs on my brother's garage wall... BG |
| Author: | xjarhead [ Wed Jun 19, 2013 8:42 pm ] |
Doc has the oil pumps your talking about. There's more to them then just the gear he puts on them. Read this http://www.slantsix.org/forum/viewtopic.php?t=29492 Lot of Q&A on what he does to the pump. Dave |
| Author: | DusterIdiot [ Wed Jun 19, 2013 8:58 pm ] |
| Post subject: | Pull and check first. |
Pull and check to see what happened before speculating, first. I've actually had a few Melling pump failures, but never had the gear go bad. I now swap an OEM gear onto the pump or use one of Doc's gears. I know I'm curious to see what happened, and will keep my fingers crossed it isn't something catastrophic. -D.Idiot |
| Author: | '67 Dart 270 [ Thu Jun 20, 2013 10:13 am ] |
| Post subject: | Thanks, yes... |
I'm very curious as well, I only meant to speculate in an attempt to allay my worst fears. Plus I can't get in there until the weekend... In the meantime, no matter what the outcome, I'm gonna need one of Doc's pumps going forward; I can't drive it again with an aftermarket pump, never knowing when its going to (or might) fail... I'm only assuming its the oil pump due to the proximity of the exterior fresh oil, and having read stories on this board about aftermarket pumps failing/being the weakest link. BG |
| Author: | '67 Dart 270 [ Sat Jun 22, 2013 1:38 pm ] |
| Post subject: | oil pump failure... |
I pulled the dizzy and the gear is shredded. The cam gear appears to be torn up pretty badly as well. I found some oil on the head/block seam under number one plug, not sure if it splashed up there or the head gasket is also involved, likely the former. Pulled number one plug, dry and clean, tube seal intact. I apologize for not posting pics, I'm not adept at webspaces and URL's. The nice thing is that my iphone fits down in there really well, and with the flash caught a pretty good image of the shredded gears. The oil pump gear appears to be intact, but pretty torn up. I can share pics via email if anyone is interested. I took pics of the lower half, I don't see any breaches anywhere, block or oil pump, but there's oil everywhere down there. I'm wondering how it got out of the system... So, it looks like the engine will have to pulled, carefully inspected, and at least a new cam and oil pump (dizzy gear), hopefully nothing else was torn up or scored in there. Indeed it seems like oil pump failure to me. BG |
| Author: | '67 Dart 270 [ Thu Jul 04, 2013 10:47 pm ] |
| Post subject: | oil pump in good shape? |
I pulled the engine today...the cam gear and distributor gear (nylon) are both shredded...but the oil pump gear appears to be spotless, not a mark on it. Also, it turns freely, the pump appears to be OK, at least from a cursory inspection. I pulled the pump off, and I can see the pump mechanism seems to work fine when I turn the gear. I haven't pulled the little cover plate off the oil pump to look in there, but perhaps that'll tell me more. Has anyone ever had this happen? Recall, I was driving down the highway, about 65mph, heard a very loud "bang" and she died. There was oil all around the oil pump area. How did it get out of the block? The oil filter case and seal were intact, the seal around the oil pump seemed intact, no breaches in the block. I pulled the oil pan and valve pan, and I can't find any signs of damage to the rods, rockers, pistons, bearings, and it turns over smoothly manually with a torque wrench on the harmonic balancer bolt. I did find pieces of the cam gear teeth in the oil pan, but that's it. No bent push rods, nothing out of place, no holes in the pistons, everything looks fine. The distributor shaft rotates freely as usual, just the gear is shredded. I did notice just after the bang happened the oil light came on rather quickly, before the rpms were down much which also suggested oil pump failure. Can oil pumps seize up and then break free? Could there have been a blockage that made a pressure spike to freeze it up? Could it be that the cam gear simply failed? I was expecting to find the oil pump mechanism all tore up, but the only thing was the cam gear and the distributor gear...very strange. Any thoughts? Thanks All, BG |
| Author: | Reed [ Thu Jul 04, 2013 10:55 pm ] |
pics to: reedspeirlaw@seanet.com and I will post them for you. |
| Author: | DusterIdiot [ Thu Jul 04, 2013 11:15 pm ] |
| Post subject: | Couple ideas... |
Pending pics, and you opening the oil pump cover to see what the rotor and ring look like. Possibly this is your scenario: Piece of something gets caught between the cam gear and the distributor gear, shredding the nylon gear putting the dizzy out of time...the bang could have been a backfire out the carb if the spark occurred while the intake valve was open(if you've ever turned the dizzy by hand while the key is on and not in the block it sounds like a short barreled 12 gauge shotgun going off in front of you)...if you didn't have the donut seal and/or the shaft seal on your distributor when you installed it, there's enough clearance there to cause a leak if the crankcase is pressurized, and if the dizzy was "cocked" a little in the bore, it'd leak better... Sounds like a new cam, and dizzy gear to put it back on the road. -D.Idiot |
| Author: | '67 Dart 270 [ Fri Jul 05, 2013 8:57 am ] |
| Post subject: | possible scenario |
Thanks, I definitely had a new large and small O-ring on the distributor, and I didn't see any oil around the top of the shaft around the bar with the adjustment slots. It was a new dizzy with no play in the shaft. You may be right on the carb popping, I did see some signs of a backfire there. Indeed, the bang was like a 12 gauge under the hood, but I could have sworn it was lower in the engine comparment. I don't currently have any carpet or sound insulation in the car or on the firewall, so I can hear pretty good what goes on in there. When I saw all that oil around the pump and dripping off the torsion bar, but no connecting rod hanging out of a hole in the block, my assumption was oil pump. I still can't figure how it got out of the block...maybe the pressure spike allowed it to escape past the oil filter seal like a burp, must have been some kind of pressure to do that. I had an RV cam in it, I believe it was 252 duration, I don't know the brand. Any advice on a bullet proof mild cam? I liked the performance of the camshaft (had my head shaved 0.035), I would try again if it was just the oil pump seizing up. I'm wondering if the cam lost a small piece of a tooth and that got sucked through the sump, and locked up the pump mechanism. Yes, I think you're right, a new cam and lifters and I'm back on the road. I'll get an oil pump from Doc, let me know if anyone has advice on a good cam/lifter set. I'll spend a little more to get a solid set and perhaps a bit more umph if it'll still run on pump gas. Now's the time, I've got her pulled. Thanks all, BG |
| Author: | DusterIdiot [ Fri Jul 05, 2013 9:11 am ] |
| Post subject: | Ocg |
I think OCG 819 would be the direct replacement and can be done on your original cam (not this one that just choked), if you still had it. 252 duration would be a comp cam and they've been hit and miss on blank quality in the past. -D.Idiot |
| Author: | Reed [ Fri Jul 05, 2013 9:33 am ] |
PICTURES! I bet most of us wish the front end and engine on our cars were this clean: ![]() Definitely some damage going on here: ![]() Hello down there! ![]() A sad sight indeed:
| Page 1 of 2 | All times are UTC-08:00 |
