It is currently Sun Nov 29, 2026 1:32 am
PostPosted: Fri Jun 21, 2013 7:50 am
I've installed a dual remote oil filter setup in my slant, because I just flat out hate the filter setup, especially the oil dump and splatter that happens when you change filters ( 57 dollars, Summit Racing) and the one thing that has surprised me a little is how hot the oil isn't. Yesterday, I had to make a quick trip of about 175 miles, all highway, with an interstate run of about 45. On the interstate, I drove between 73 and 80 all the way. It's a 4x4 it was windy, so I was pushing against the wind. Basically running WOT much of hte time, the rest almost WOT, all of which was about 3000 rpm.
When I got to my destination, I showed the guy my propane setup and I touched the filters. You could put your hand on them without getting burned, but it was too hot for more than 2-3 seconds contact before it hurt.
I just got to wondering just how hot the oil normally runs in a hard working slant... Does anyone know?
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
