| holley 1920 fuel leak.!! https://slantsix.org/forum/viewtopic.php?t=52455 |
| Author: | 67 Dodge Coronet 440 [ Sun Jun 23, 2013 8:43 am ] |
| Post subject: | holley 1920 fuel leak.!! |
hi Barry here.i have a question but lets see if I can get it right..i have a Holley 1920 1 bbl.carb and I have a leak below the bowl where the rod goes through. just above the bottom of carb in the front..when I operate the throttle it leaks from there onto the manifold..what is the reason for this,and how easy of a fix is it....I have parts carb im lookin at,but I don't see why this would leak there.please help..thanks and God Bless......Bear R.- |
| Author: | Aggressive Ted [ Sun Jun 23, 2013 8:56 am ] |
It sounds like your float is too high if that much gas is going in....or the needle and seat are so worn that it can't shut off the fuel. Replace that first and see if it stops. Does it leak with the engine off? or does it leak with the engine running? How well does this engine run? It must be running super rich! |
| Author: | 67 Dodge Coronet 440 [ Sun Jun 23, 2013 9:10 am ] |
1st it runs great...and it leaks w/the engine running and off..it dosent seem to be running rich but ill check everything out. but will look for your next reply .thanks and God Bless.Bear R.- |
| Author: | 67 Dodge Coronet 440 [ Sun Jun 23, 2013 9:22 am ] |
Quote: 1st it runs great...and it leaks w/the engine running and off..it dosent seem to be running rich jet is set at 2 1/2.but ill check everything out. but will look for your next reply .thanks and God Bless.Bear R.-
| Author: | Aggressive Ted [ Sun Jun 23, 2013 9:39 am ] |
It probably needs a new needle and seat. After three years I had to change mine again. I am not sure if the new gas has something to do with the needle tips deteriorating......but mine did the same. It is a 10 minute or less job from start to finish. It should cure your problem. Unscrew the inlet and replace, don't for get to check float height. Remove the the four screws holding the bowl on, to view the float height. |
| Author: | 67 Dodge Coronet 440 [ Sun Jun 23, 2013 9:44 am ] |
Hi Ted..thats great I will do that ASAP..but I said it leaks while running but made a mistake.its only when the engine is off.dont know if this will help w/the issue or a more simple one..thanks and God Bless..Barry |
| Author: | Aggressive Ted [ Sun Jun 23, 2013 9:49 am ] |
One solution fixes both issues....you need to get the fuel shut off....change the needle and seat. |
| Author: | 67 Dodge Coronet 440 [ Sun Jun 23, 2013 12:43 pm ] |
Thanks Aggressive Ted... changed the needle off /my spare carb.it runs even better than it did.but still leakin when shut off.i will have to get a new needle..thanks for everything ...God Bless.Barry |
| Author: | matv91 [ Mon Jun 24, 2013 3:41 am ] |
Is the leak like the one in this thread http://www.slantsix.org/forum/viewtopic ... d4798fe517 |
