It is currently Sat Nov 21, 2026 6:43 am
PostPosted: Thu Jun 27, 2013 6:45 am
When switching from 12 to 134a do you charge the same amount of gas back into
The system? My volare calls for 42 oz of r12.
I was going to charge it with the same amount of 134a..
Would this cause any problems?
Thanks Greg [/b]
PostPosted: Thu Jun 27, 2013 9:39 am
Thanks Greg [/b]
AC systems should be charged by temperature and pressure readings, especially if converting from R12 to 134A. Most conversions of this nature involve modified parts, different valves, etc. and can be a real hit and miss.
You cannot guaranty results by weight alone.
As a side note, what oil are you using in your conversion?
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Thu Jun 27, 2013 4:35 pm
Well it took about 19 oz of 134a.
I replaced the c171 compressor due to a crankshaft seal leak that would
loose a full charge of r12 after a few months.
I used ester oil and. After getting to about 20 psi. On the low and 220 psi
On the high side and forty degrees of duct temp 19 ounces worked well
