It is currently Sat Nov 28, 2026 5:43 am
PostPosted: Fri Jun 21, 2013 4:28 am
A buddy is enlisting me into his project. He is looking at buying a 74 dart swinger. 225 super six automatic transmission 2door car. He knows very little about auto mechanics. He was wanting a big block mopar muscle car but the budget is not there for that and it needs to be a daily driver. So I got him looking at abodies instead. He does not need a race car but wants the power to scoot around light to light. My question is what kind of petformance can the slant make still using all the emissions crap from the 70s. I have my 64 and don't have to worry about emissions and can build what ever I wish but his 74 will need to stay emissions compliant and I have never messed with a slant car newer the 66.
I know 2.25" exhaust is first on the list after rebuilding the supersix and getting it up and running. Can you do hei conversion with a recurved dizzy with lean burn? Up the compression and new cam maybe rv15 or erson270 but needs to go well with stock converter. And a shiftkit in the trans. Would this be a decent cruser and still stay ep as complient?
 Post subject: Woof
PostPosted: Fri Jun 21, 2013 7:37 am
I'm suprised he has to stay compliant as most states have the cut off at 1974 for a tailpipe sniff (1975 being the starting year dues to catalytic convertor).
Changing the rear ratio to 3.23 and tail pipe to 2.25" would make it more fun to drive, the Holley 1945 would need to be upjetted to make it worth it. The super six would also be a good upgrade if you can get everything to work right. You will have to be careful about the engine rebuild as bigger cams have bigger overlap and you may end up with a little unspent gas or high nox in the tailpipe (you can cheat and run E85 in the tank for the test). Leanburn distributors have no guts they rely on the ESA computer to correct the timing, so a regular distributor would need a recurve, but it's a heavy car so the curve won't be a spritely as one for your car would be.
PostPosted: Fri Jun 21, 2013 10:19 am
The cut off year is 1967 and newer have to be tested in AZ if you are registered in Tucson or Phoenix metro area. You can get it exempt by registering the car as a classic or collectors car but it also has to be insured the same way.
I am told the car has a 2bbl on it already not sure which carb though. Its been sitting for 6 years and has no radiator, but from the pictures its super clean inside and out with no rust AZ car. And the guy selling it only wants $450 for it.
 Post subject: Nice...
PostPosted: Fri Jun 21, 2013 11:45 am
Price is really good, just hook everything back up, and upsize the tailpipe and get it tuned up and it should be a goer (swap out the 2.76 rear for 3.23's and it will really perk up).
PostPosted: Fri Jun 21, 2013 5:24 pm
PostPosted: Sat Jun 22, 2013 9:11 am
Mike_64_Valiant,
I have a 74 Swinger and have done just that....
The biggest bang for the buck is compression. It makes a huge difference in how the engine feels. You can even keep the tall gears if you do an engine build. You can take a look at mine by clicking on the red link below my name and looking at the Engine FAQ, "Engine Build Matrix" section on this site. My build is listed there. Next is the larger exhaust and I would say third is recurving the distributor. Those (3) mods made both rear tires spin at will.
PostPosted: Mon Jun 24, 2013 8:01 am
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
