It is currently Sat Nov 28, 2026 2:59 am
 Post subject: Oil w/ zinc
PostPosted: Fri Apr 05, 2013 11:34 am
I've heard the the zinc has been taken out of the diesel oil formulations now, too. Is there any way to tell if there is zinc in the oil?
PostPosted: Fri Apr 05, 2013 12:57 pm
Zinc (or rather ZDDP) has NOT been removed from either passenger car or heavy duty engine oils. The current CJ-4 specification LIMITS phosphorus to 1200 PPM, which is still plenty for OEM flat tappet valve trains. You can still use the older CI-4 spec but there is no guarantee that you will be getting higher amounts of phosphorus although many 15W-40 grades had almost 1400 PPM of P.
Engine Oil Article
PostPosted: Fri Apr 05, 2013 1:53 pm
Read this thread.
first post and post from david_Navone.
you can make up your own mind if you need it or not.(ZDDP the P does the protecting)
http://www.bobistheoilguy.com/forums/ub ... 812&page=1
the oil manufacturer should have all the details on a web page like this...
http://www.penriteoil.com.au/pis_pdfs/H ... 202012.pdf
Brendan.
1963 AP5 Valiant 225 PB 904 Stock except extractors & 2 1/4 inch exhaust.
1962 S series valiant 225 PB auto. factory every thing. Full restoration job.
Currently on hold till AP5 is on the road.
PostPosted: Sat Apr 06, 2013 11:55 pm
detergent levels have increased. Which means the noble metals will be stripped from surfaces. Go non-detergent if your not gong to run specialty oils. Add your own ZDP additive regardless.
Now your know. I'm doing custom oil in the race cars after a flat cam episode...
PostPosted: Sun Apr 07, 2013 8:06 am
I disagree. It is never a good idea to run an API SA (non-detergent) oil in an engine newer than 1930 and I don't think that anyone can formulate better additive packages than engine oil manufacturers. Detergents additives bond to metal surfaces an prevent contaminants from attaching. Dispersants keep contaminants from agglomerating (massing together). Anti-wear additives (ZDDP) also bond to surfaces to form a sacrificial wear layer. What noble metals are stripped from surfaces?
PostPosted: Sun Apr 07, 2013 9:10 am
Zinc.
Scrubbed a cam last year believing exactly what you posted there. Valvoline Synthetic. Detergent levels have been increased, and are competing with ZDDP.
Try this: http://home.physics.wisc.edu/gilbert/pu ... ns/101.PDF
I do not, and will not daily drive any engine this old. My personal choice in the environmental game. If your going to daily drive a slant, then detergent motor oil makes sense. Just stay away from high lift and spring rates.
PostPosted: Sun Apr 07, 2013 1:58 pm
That research paper makes for good bed-time reading. However, the oil used in those experiments was Mobil 1 5W-30, which is an API Starburst oil with a phosphorus (P) content of 750 PPM. Starburst oils are limited to P contents of 600-800 PPM to protect the catalytic converter.
Widman (the author of the Covair Oil Article) does not recommend Starburst oils for flat tappet valve trains and instead recommends Heavy Duty Engine Oils (HDEO), preferably with a CH-4 or CI-4 service classification, which do not have limits on P content. CJ-4 class HDEO is limited to 1200 PPM and, even with the CI-4 classification, generally only the 15W-40 grades got P contents approaching 1400 PPM. As long as the HDEO is dual-rated (like CJ-4/SM or CI-4+/SL), it is perfectly safe to use in gasoline engines.
The OP didn't mention whether he had a high performance aftermarket valve train and my guess is he drives it regularly. For OEM-style valve trains, API CJ-4/SM should be fine. Now that my disc brake upgrade finally done, my 65 Barracuda (with DC P4120243 Cam & 340 valve springs) is a daily driver and I've running PC Duron-E and Shell Rotella T for over 5000 miles now.
What synthetic Valvoline oil were you using?
To what P level (in PPM) are you blending your SA oil?
PostPosted: Sun Apr 07, 2013 6:45 pm
Can't remember which Synthetic. Whatever the over the counter stuff was.
4 oz. ZddpPlus in five quarts. Whatever that works out to. I only use that combination for cam run in. My operating oil is Joe Gibbs 10W30 Hot Rod Synthetic.
It's quite possible the Valvoline was a starburst. Took about six days at the track to wipe the cam with it. Flattened #5 out pretty good. The others showed quite a bit of wear.
PostPosted: Sun Apr 07, 2013 6:56 pm
Comp was telling folks to use Rotella.
PostPosted: Mon Apr 08, 2013 12:05 am
I use brad penn
PostPosted: Mon Apr 08, 2013 6:56 am
Joe Gibbs Hot Rod HR 10W-30 contains 0.127% wt% (1270 PPM) of Zinc (Zn). In comparison, Delo 400 LE SAE 10W-30 contains 0.11% (1100 PPM) of P and 0.120% (1200 PPM) of Zn. I would say that the Joe Gibbs HR product contains a similar amount of ZDDP as CJ-4/SM HDEO but at a premium price.
Brad Penn's Penn Grade 1 High Performance Oils all contain 1400 PPM of phosphorus, which is the maximum that Widman recommends. The CI-4 oils that Widman recommends for maximum valve train life typically contain 1000-1200 PPM of P.
Since the additives are polar, they fight for surface area. The addition of extra ZDDP usually results in reduced cleanliness, higher engine temperatures and more deposits. Some studies have shown that going past 1400 ppm of phosphorus will increase wear over the long term, and going above 2000 ppm will begin to break down iron and result in camshaft spalling.
Adding 4 oz of ZddPlus to 5 quarts of oil results in 1200 PPM of phosphorus. See ZddPlus Certificate of Analysis. If your oil already has 600 PPM of phosphorus (minimum limit of a Starburst oil), adding 4 oz to 5 quarts of a Starburst oil will result in a phosphorus content of 1800 PPM, which would be excessive.
PostPosted: Mon Apr 08, 2013 7:32 am
I really hate to get on these oil threads. People get way out there and buy over priced, unnecessary, over touted oils. Many of the racers on Moparts use diesel oil with no problems.
There was a big discussion about adding ZDDP and detergents ruining it etc. etc.
PostPosted: Mon Apr 08, 2013 5:49 pm
Diesel oil with no problems, I second that
PostPosted: Tue Apr 09, 2013 8:32 am
This is what I was told to use my some other Mopar guys. Just an opinion.
http://mustangs.about.com/od/accessorie ... e-Defy.htm
PostPosted: Tue Apr 09, 2013 1:27 pm
Someone at BITOG did a VOA on QS Defy 5W-30 in 2012 and found it contains 735 PPM (probably measured a bit low) of phosphorus. The UOA came back at 904 PPM of P.
QS Defy 5W-30 VOA
QS Defy 5W-30 UOA
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 7 guests
