Strange vibration/sound
https://slantsix.org/forum/viewtopic.php?t=52482
Page 1 of 1
Author:  ESP47 [ Mon Jun 24, 2013 10:10 pm ]
Post subject:  Strange vibration/sound
Running a regular 1bbl slanty in a 67 Valiant I got from a guy a few years ago. Haven't really put much work into it other than rebuilding the carb, adjusting the valves and putting an HEI ignition in it. At idle it purrs like a kitten.
When I get on the gas, the engine starts to get a little bit of a solid vibration as I get going. Nothing major but my Duster doesn't vibrate like that at all.
Once I hit about 50, I get this weird rhythmic vibration and sound. Every 3/4 of a second or so I get a vibration and it sort of sounds like the engine is raising a couple hundred RPM's but I don't think it is. So once you cross 50mph on the highway its just vroom....vroom....vroom....vroom. The faster you go, the faster the rhythm gets.
It doesn't quite sound like a wheel bearing or anything like that because the rhythm of the vibration is slow compared to how quickly the wheels are moving. I could be wrong though so let me know if you guys have any ideas on what it could be.
Author:  mattelderca [ Tue Jun 25, 2013 4:55 am ]
Drive shaft needs to be balanced. At leats that's my first thought on this type of vibe.
Author:  75valiant [ Tue Jun 25, 2013 9:26 am ]
certain it's not a tire noise?
Author:  ESP47 [ Tue Jun 25, 2013 10:08 am ]
I'm certain it's not a tire deal because I had the vibration before and after I put new rubber on it.
I'll have to check out the driveshaft...didn't even think of that. Thanks.
Author:  robertob [ Tue Jun 25, 2013 10:14 am ]
I had a driveshaft that was shortened by a sloppy shop and it exhibited that exact symptom. Once I had it balanced it was much better. There is instructions for setting driveshaft balance with a couple of hose clamps in the MP racing manual.
Author:  Doc [ Tue Jun 25, 2013 10:38 am ]
To Test, get to speed where the vibration occures and shift to neutral, so engine RPM go to idle speed...
If the vibration stops, it's engine / converter related.
If the "vib" is still there... it's trans/ chassis related.
Has the engne been swapped?
Does the engine have 5 freeze plugs?
If so, it could be that someone replaced the engine with a later one ("big hub" crank flange) and they did not use the special adapter bushing needed to center-up & support the front of the torque converter.
Author:  DusterIdiot [ Tue Jun 25, 2013 12:30 pm ]
Post subject:  Also...
Note that some of the late 60's cars came with the composite driveline, where the front yoke is welded to the outer tube, the tube is lined with a rubber sleeve and the rear yoke is welded to the inner tube inserted into the aforementioned assembly...this was to reduce driveline vibrations and noise...if they get old or too much "launch" the inner will move compared to the outer and come out of balance...(my'67 Valiant had this type of driveline...)
Hopefully this isn't the case as they are not fun for the driveline guy to weld on without making a shallow weld (the added weight takes a skip off the driveline at high rpm), or he lights the rubber on fire in that area creating a weak spot.
Keep my fingers crossed that you can narrow it down per Doc's recommendation, and it's something easy to remedy.
-D.idiot
Author:  ESP47 [ Tue Jun 25, 2013 3:34 pm ]
Yep it has 5 freeze plugs :( I pulled it out of a 67 Dart so I just assumed it was pre 67...stupid of me.
So where do I go from here? Have I caused any damage to the crank/converter or can I throw an adapter on and drive it ok? The vibration seems worse now and I can hear it as soon as I put it into gear without the car moving. On the freeway I put it in neutral and all the noises went away so it looks like it's pointing towards the missing adapter as the most likely culprit.
Author:  Doc [ Tue Jun 25, 2013 4:15 pm ]
To confirm, pull the torque converter inspection cover, mark the flexplate to converter position, (spray paint a "lug") remove all the FP to converter bolts then see if there is a lot of "up-down" converter movement, if you carefully lift the converter. (I use a big screw driver, between the ring gear and bellhousing)
There should be little to no movement.
If there is significant movement, it is best to pull the trans., install the adapter ring and replace the front pump bushing & seal.
Author:  mattelderca [ Wed Jun 26, 2013 4:49 am ]
I guess there is a reason they call you Doc!
Would it be a good idea for him to do a thorough inspection of the flexplate as well? I would think you could get stress cracks in it supporting the converter by itself.
Author:  jhdeval [ Wed Jun 26, 2013 8:01 am ]
Stupid question but does it matter if the flexplate and torque converter are installed in the same position? I just rebuild my engine and replaced everything including adding the adapter but I have no idea what position I was in before I removed it.
Author:  Fopar [ Wed Jun 26, 2013 8:27 am ]
Flexplate to converter bolt holes are not even they have to be in correct position to get all in the first time. :shock: :lol: :lol:
Richard
Author:  jhdeval [ Wed Jun 26, 2013 8:41 am ]
Well then I have some damn fine luck. I got it first time.
