It is currently Fri Nov 20, 2026 1:39 am
PostPosted: Fri Jul 05, 2013 7:48 pm
Hello,
I recently Bought an original 24,000 Mile F body with a Leaky Shift shaft seal (the One the Operates the Gear Selector on the Valve body).
Question is on a f body trans tunnel with a 904 trans and the Seal removal / install tool, can I replace this seal without Dropping / lowering the trans?
I was curious if anyone has done this in the car without tilting the back of the trans down for access / clearance?
Again, I have the tool for getting the old deal out and pressing in the new one.
Thanks,
PostPosted: Mon Jul 08, 2013 10:01 am
I do this seal change all the time... with a "home-made" tool, with no problem doing the work, under the vehicle.
I do remove the rear cross member and lower (tilt) the engine / trans. assemble, for better access.
PostPosted: Mon Jul 08, 2013 5:30 pm
Cool.
That's what I thought i might have to do.
