| Lifter question https://slantsix.org/forum/viewtopic.php?t=52500 |
| Author: | icepaddles [ Wed Jun 26, 2013 1:23 pm ] |
| Post subject: | Lifter question |
It seems the stock solid lifters are quite light in weight seeing the thin mid section, I would like to know if the after market ones are heavier and if the weight is justified through high performance abuse. In other words do the stockers hold up to the rigors of drag racing with big cams? |
| Author: | Doc [ Wed Jun 26, 2013 1:28 pm ] |
The lightest solid lifter I have found was 83 grams. ("barbell" style) The heavest one was an aftermarket unit weighing 118 grams. (straight cylinder style) I have never had a lifter problem with a SL6 engine. DD |
| Author: | DusterIdiot [ Wed Jun 26, 2013 1:38 pm ] |
| Post subject: | X2 |
I ran a set of stock barbell regrinds on my last hi compression mill and they had no problem at 6200 rpm on a .539 lift 250/250 @ .050 duration... they looked great when I transferred the cam and lifters to another engine... -D.Idiot |
| Author: | icepaddles [ Thu Jun 27, 2013 8:34 am ] |
Thank you, seems like donation time. |
