| carb to kickdown linkage https://slantsix.org/forum/viewtopic.php?t=52501 |
| Author: | jhdeval [ Wed Jun 26, 2013 1:46 pm ] |
| Post subject: | carb to kickdown linkage |
Anyone have a good pic of how to hookup a lokar style linkage to the carb? |
| Author: | Fopar [ Sat Jun 29, 2013 10:52 pm ] |
If that is for the transmission down shift you got it backwards. The throttle should pull the lever on the transmission towards the rear of the car, and the spring should pull that same lever to the front of the car. Richard |
| Author: | jhdeval [ Sat Jun 29, 2013 11:03 pm ] |
I am sorry fopar you are right and that is how I hooked it up. My only other question is when setting the tension should I pull the cable to have "zero lash". This would mean as I hit the accelerator the kickdown will mirror the movement. |
| Author: | Fopar [ Sun Jun 30, 2013 8:50 am ] |
Adjust so when full throtle you have kick down, may have to play with it for proper up shifts. Richard |
