It is currently Fri Nov 27, 2026 5:14 pm
PostPosted: Thu Jun 27, 2013 1:02 am
I am looking for a radiator for a 74 dart swinger with 225 auto and a/c.
The previous owner removed the radiator saying it was bad because the plastic coolant tank kept exploeding. I am not sure where his thinking is on that but what ever. We have a busted coolant can and no radiator. Can we get a radiator that has its own tank to it with a proper cap and just use a over the counter catch can.
Where should we look its an az car so it will see 100+ degree temps, but we are also budget concious.
 Post subject: You can..
PostPosted: Thu Jun 27, 2013 7:19 am
Catch can is universal if just needing a catch, there are aftermarket ones available at the auto parts store.
225 with A/C or Heavy Duty use is available Modine/Spectre/Murray with part numbers engine in 497 (the 22" wide core ) and is a bolt in.
PostPosted: Thu Jun 27, 2013 11:09 pm
dusteridiot;
I just ordered a spectra cu527 radiator, it suppose to be 22" x 19" and is heavy duty, I just have an ordinary slant 6, I am hoping it is a bolt in. The 497 that you mentioned is almost the same, do you know what the difference is? the 497 cost about $50 more. I think it has a bigger transoil cooler.
I know in the next few days if the cu527 is a bolt in, fed ex is delivering it Saturday.
PostPosted: Thu Jun 27, 2013 11:57 pm
The previous owner removed the radiator saying it was bad because the plastic coolant tank kept exploeding. I am not sure where his thinking is on that but what ever. We have a busted coolant can and no radiator.....Where should we look its an az car so it will see 100+ degree temps, but we are also budget concious.
I wonder if the "exploding" was actually overheating causing boil over into the stock overflow tank. I would take tis opportunity to check out the rest of the cooling system. Check your thermostat, check for sludge buildup, reverse flush the system, if possible.
PostPosted: Fri Jun 28, 2013 1:52 am
The guy my buddy is getting the car from thinks possible wrong radiator cap pressure. Regardless the car has not ran it about 6 years so I am going to do a full flush on the coolant plan to do the vinegar wash, new radiator, t stat and hoses. Trans flush inspect and change filter, new belts battery, all new brake hoses and brake job, fuel tank cleaned, super six carb rebuilt, complete tune up, the fuel line mod.
Just trying too get it running safely and reliably then the interior and performance can come later.
 Post subject: It's...
PostPosted: Fri Jun 28, 2013 7:25 am
The 497 is for the later cars 1975+, and has a larger fin area for more air flow through the radiator( about 1.5-2") , the other good feature is the overflow nipple on the radiator neck is pointed toward the passenger side fender which is the best place to stick an overflow bottle, the 527 would be correct for the 73/74 because they didn't have an over flow and the tube just pukes to the ground, so the tube points to the battery tray. Other than that I don't see anything else to be alarmed about.
PostPosted: Fri Jun 28, 2013 11:21 pm
D.idiot;
thanks Jerry
PostPosted: Fri Jun 28, 2013 11:26 pm
http://slantsix.org/forum/viewtopic.php ... n+radiator
Catch can is towards the bottom of the page.. Its cheap and it works.
70 Plymouth Valiant 4dr
