It is currently Fri Nov 27, 2026 9:57 pm
PostPosted: Thu Jun 27, 2013 4:53 pm
I've had a tough idle with this carb since it was rebuilt. It was never constant, but I noticed intermittent tough idle, where I would need to feather the gas sometimes. If I didn't, and it stalled I would notice that it would be flooded when trying to restart.
Today, I finally saw what was happening. When staring down the throat of the carb, I saw fuel dripping from (don't know what they are called, look like turbines lol).
When I press the gas, the plates open and air is allowed in, helping the mixture.
What could be causing a fuel leak in this location?
69 Plymouth Valiant
PostPosted: Thu Jun 27, 2013 7:06 pm
Most likely a bad power valve What type of carb is it?
Brian
63 Plymouth Valiant Wagon
PostPosted: Thu Jun 27, 2013 8:18 pm
If you're dribbling fuel from the booster venturi at idle then most likely the float level is too high, the float is bad, or the needle and seat are dirty or defective. The power valve will affect how much fuel comes out of the main circuit when the main circuit is operating, but fuel out the mains at idle with this type of carb it's not the power valve as the power valve diaphragm is above the fuel level.
PostPosted: Fri Jun 28, 2013 10:08 am
Thanks. I've had problems with too high float or stick needle and seat before so that's likely the cause again.
69 Plymouth Valiant
