It is currently Sun Nov 29, 2026 1:00 pm
 Post subject: Dim taillights
PostPosted: Sat Jun 29, 2013 7:02 am
I noticed my taillight is dim on the left side only. Not the brake lights, the brake lights on both sides are NOT dim, just the taillights. The reverse light is also dim. The filament gets brighter the longer the car is in reverse but never as bright as the right side. Any ideas?
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Sat Jun 29, 2013 4:05 pm
Bad ground
2 different types of bulb
You're seeing things
