| Leaky Valve Cover https://slantsix.org/forum/viewtopic.php?t=52530 |
| Author: | nicholas482109 [ Thu Jun 27, 2013 2:26 pm ] |
| Post subject: | Leaky Valve Cover |
I can't seem to stop oil from leaking out of my valve cover. I must have over torque the bolts and warped the cover in some way. Yesterday I installed a new one gasket (Rubber Fel-Pro), smeared both sides of the gasket with white lithium grease but it's till leaking a bit. I can see oil on top of the coil and plug wires and a bit where ever I park. Any advice on a way to seal this up better? I've read blue hylomar works well and doesn't dry. I've never used this stuff before, is it my best bet? If it doesn't dry will it work it's way out from engine vibration? I am fairly certian I know of a valve cover I can pick at a bone yard and will probably grab that this weekend on my search for a fuel sender ground strap. |
| Author: | DadTruck [ Thu Jun 27, 2013 3:55 pm ] |
The only time I use grease on a gasket is if it is a blind fit and I want it to stay in place where set.....for the valve cover a light twist with a ratchet is about all you should need. If over tightened you will draw a little hump into the metal where the bolts go through. You should be able to work those out with a light hammer and a flat surface to hammer against. If the vc is leaking with a new gasket check to be sure all the old gasket is cleaned away and when you tighten the vc with the new gasket start with the center bolts and work outwards tighten about half torque then go around them again from the center out and snug em up. |
| Author: | Reed [ Thu Jun 27, 2013 3:55 pm ] |
First, pound the valve cover area around the bolt holes flat using a hammer and a suitable anvil-like item. Second, run a small (SMALL) bead of RTV sealant on both sides of the gasket and let it cure for about 15-20 minutes. Then assemble it all. |
| Author: | 65CrewCabPW [ Thu Jun 27, 2013 4:20 pm ] |
You can, of course, glue it, or adhere it with silicone sealant. But, that complicates removal and replacement. That's ok, if you know you're not going to Once in a while, if you do it JUST right, you can get it pretty much sealed up with a rubber gasket and just the right amount of torque - assuming your cover itself isn't bent or warped... My experience over the years says that I have the greatest luck when I keep my tounge planted firmly in left cheek when I'm assembling it. |
| Author: | nicholas482109 [ Thu Jun 27, 2013 5:01 pm ] |
Quote: ... If over tightened you will draw a little hump into the metal where the bolts go through. You should be able to work those out with a light hammer and a flat surface to hammer against. If the vc is leaking with a new gasket check to be sure all the old gasket is cleaned away and when you tighten the vc with the new gasket start with the center bolts and work outwards tighten about half torque then go around them again from the center out and snug em up.
Definitely have humps for over tightening when it first started leaking. So pound the underside of the VC to get to back to level?Quote: First, pound the valve cover area around the bolt holes flat using a hammer and a suitable anvil-like item.
So let the RTV dry on the gasket with out the gasket on the vc or head? Do you hang the gasket to let it cure?Second, run a small (SMALL) bead of RTV sealant on both sides of the gasket and let it cure for about 15-20 minutes. Then assemble it all. Quote: You can, of course, glue it, or adhere it with silicone sealant. But, that complicates removal and replacement. That's ok, if you know you're not going to
I'm hoping to avoid doing this, but it did cross my mind. Man hylomar is hard to find too!
| Author: | Reed [ Thu Jun 27, 2013 5:06 pm ] |
I hang the gasket to let it cure. Basically you want to let the RTV sealant skin over so it makes less of a mess on installation, but is still pliable enough to pop and ooze out when you bolt it down. Any sort of sealant or glue should really be a last resort. Try a rubber gasket and pounding the valve cover holes flat first. |
| Author: | DadTruck [ Thu Jun 27, 2013 5:47 pm ] |
Getting the gasket to compress evenly is the key. Tighten from the center out, like you would do a cylinder head and bring it down in stages. There should also be washers under the bolt heads to help spread the clamp load. |
| Author: | Reed [ Thu Jun 27, 2013 7:14 pm ] |
Unless I am mistaken, the triangle washers off of V-8 motor valve cover bolts work great on a slant six. You can even use the fancy chrome ones. |
| Author: | DusterIdiot [ Thu Jun 27, 2013 8:06 pm ] |
| Post subject: | Yep... |
Quote: Unless I am mistaken, the triangle washers off of V-8 motor valve cover bolts work great on a slant six.
There were a couple of 80's pickups in the junkyard that had this "upgrade", looked so great I swiped a set just for such and occasion...Keep your eyes peeled when picking up that other valve cover. -D.Idiot |
| Author: | nicholas482109 [ Fri Jun 28, 2013 2:47 pm ] |
I like a good scavenger hunt on a Saturday morning. Any makes/years I should look out for for these triangle bolts? |
| Author: | DusterIdiot [ Fri Jun 28, 2013 3:20 pm ] |
| Post subject: | 80's |
Quote: Any makes/years I should look out for for these triangle bolts?
Just the late valve covers from the 80's trucks and vans...note that these valve covers will be different because of the late hydro valve train head so don't use them on your motor they will not fit right, period.-D.Idiot |
| Author: | olafla [ Fri Jun 28, 2013 4:03 pm ] |
http://www.realgaskets.com/files/automobile.htm Quote: These silicone rubber gaskets, which are made from aerospace mechanical grade AMS silicone, are 100% reusable, designed to withstand temperatures up to 400°F, and to last the life of the engine.
Olaf
| Author: | mattelderca [ Sat Jun 29, 2013 6:41 am ] |
Quote: I like a good scavenger hunt on a Saturday morning. Any makes/years I should look out for for these triangle bolts?
If you can't find any at the yard, you should be able to pick these up at any local speed shop.I assume these would work and they're cheap enough. http://mr-gasket.com/engine-components- ... large.html |
| Author: | ILMopars [ Sat Jun 29, 2013 6:53 am ] |
I had a similar problem with a rubber gasket. I pulled the valve cover and found that it had shrunk, cracked and was just blowing it out from the crack. I have never had problems with the cork/rubber composite gaskets. |
| Author: | nicholas482109 [ Sat Jul 06, 2013 1:07 pm ] |
| Post subject: | Update |
I found some of trianglular washers at o'reilly's. I installed the cover with white lithium greese on both sides of the gasket. I actually took my torque wrench out this time. Has not leaked since. Those washers are definitely a improvement. |
