It is currently Fri Nov 20, 2026 2:48 pm
 Post subject: trans stuck in reverse
PostPosted: Mon Jun 24, 2013 8:10 pm
my friend has a 64 dodge dart , he replaced the trans with one from a 65 valient. It has a pushbutton shifter , he pushed the cable in and it went click. He then spun the adjuster , but it stays in reverse?
The book said about 6 turns but he's spun the thing many more than that.
PostPosted: Tue Jun 25, 2013 10:06 am
The 65 transmission has a different valve body. (6 position)
The 60-64 push button shifter only has 5 positions. (park is also neutral)
You will have to swap-in the 64 valve body in order to get the PB shifter to adjust & work correctly.
PostPosted: Tue Jun 25, 2013 6:13 pm
Yep. That is correct.
PostPosted: Thu Jun 27, 2013 10:48 pm
thks guys , is that easy to do? Can he swap the 64 valve body out of the old trans into the 65 ? and can he do it whie its still in the veh? thks again
PostPosted: Fri Jun 28, 2013 4:04 am
Yes, and Yes. Unhook the kickdown lever, Drop the trans pan, unhook the shifter cable, unbolt the valve body.
PS: It is easier to adjust the shifter cable while the pan is still off the trans.
A FYI. Make sure the filter, has two fluid flow holes. Most Filter kits come with a one hole filter for the 1966 and newer trans. 60-65 needs two hole filter that feeds oil to the front & rear pumps these transmissions have inside of them.
PostPosted: Fri Jun 28, 2013 8:36 pm
with the wrong valve body make it not leave reverse? or would it cause erratic shifting . His is stuck in reverse , and he is worried the trans is no good. I told him I posted that he trans was stuck , so your guys answer would ref that , but hes all worried :)
