It is currently Thu Nov 26, 2026 11:44 pm
 Post subject: oil pump rotor scoring
PostPosted: Mon Jul 01, 2013 11:26 am
Car Model: 1964 Valiant V200
Was planning to use the old pump in my engine build, but the rotors look like the pump ingested a handful of sand. The clearances are good but I'm hesitant to use it because I might end up with low idle oil pressure.
PostPosted: Tue Jul 02, 2013 11:38 am
Pump is jump. As much as I want to use it, the scoring is just too bad. New one on the way - I'll swap the gear from the factory pump.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
