It is currently Fri Nov 20, 2026 1:19 pm
PostPosted: Tue Jul 02, 2013 9:25 am
Car is a 1965 Plymouth Fury 2 - 4 door with a 1964 build year. When I look under the car, I see an 8.75 diff, but when I research this, it seems that the majority of Slant Six cars came with the 7.25 and I shouldn't have this rear end in there.
Now, the car is original from bumper to bumper, except for the rims and tires and windshield washer pump. Current options that I have are front seat belts and a padded dash.
Doing what I can for research, this is an 8.75 rear axle, but I have also read that some came with a 7.25 rear axle that looked like an 8.75. Can't remember where I read it, but I think it was a 70s Dart forum.
I can imagine that this could be a custom option from the dealership and that it was put in there because the original owner wanted to pull a trailer, however, there is no trailer hitch.
Diff has no tags. 3.21 gear ratio in it. Axle tubes are 3" OD. If it can't be verified for sure just from looking at it, its there any way to verify what it is without taking the ring gear out; ie measuring outside case dimensions, bolt pattern on axle flanges, rear brake shoe dimensions?
 Post subject: Yep...
PostPosted: Tue Jul 02, 2013 9:55 am
No bolts or plate in the back, so that's an 8 3/4"....she might be a 741 cased unit being that early, but plenty of options are available for that rear. The one thing to note, is that some of the early 8 3/4" had large nuts to hold the brake drums on the axle (you'll know when you take a rear tire off, you'll see it...), if you have this type of rear they are a pain to change gears in (hopefully it's a later version that did not have this feature).
Good find.
PostPosted: Tue Jul 02, 2013 10:45 am
Awesome. Thank you for the reply.
I have had the brakes off and everything replaced when I purchased the car. $2000.00 off Kijiji and 800 to safety it; exhaust manifold, brake shoes, hoses, headlight bulb, signal light bulb and a windshield washer pump.
When I did the brakes, the rear drums just slid off, no bolt holding them in. The fronts have the bolt and bearing.
I wanted to get the diff identified because I want to put an SG in there this coming winter.
Again, than you for the help.
PostPosted: Tue Jul 02, 2013 3:15 pm
Where did you get the "3.21 ratio" info?
8 3/4 has a 3.23 ratio...
PostPosted: Tue Jul 02, 2013 4:49 pm
Meant 3.23. Was a typo.
PostPosted: Wed Jul 03, 2013 11:02 pm
That's 100% 8.75 rear.
Chrysler stuff was funny like that. Often a /6 car would have a 7.25 rear but if the car was coming down the line and the 8.75 was all that was available.- the 8.75 would go in. They didn't toss them out. Most likely the Fury also had the 8.75 because of the heavier vehicle weight vs. other body styles.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Thu Jul 04, 2013 10:23 am
I'm pretty sure that '64 was the last year for the old-style tapered axles. You got lucky there (though I think the '64's were prettier cars.)
Also, I think the 8.75' rears were part of the "heavy duty" package that my dad ordered on our '62 Fury. He did pull a trailer.
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
