It is currently Fri Nov 27, 2026 1:51 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Mon Jun 17, 2013 6:00 am
Was tapping for a helicoil and the block cracked.
Weldable? Thanks guys. Getting this block back together is getting to be a little frustrating.
PostPosted: Mon Jun 17, 2013 6:27 am
<toast>
PostPosted: Mon Jun 17, 2013 8:00 am
New block time.
It might have already been cracked and that is what caused it to "strip" in the first place.
That or it was a defect in the casting and it just took time to rear itself.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Mon Jun 17, 2013 8:02 am
Duval67 where are you in the country?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon Jun 17, 2013 8:20 am
Yeah, that's what I was thinking too--about it already being cracked.
Jhdeval, I'm located in Ottawa. I go out to Guelph area frequently though due to school.
PostPosted: Mon Jun 17, 2013 8:22 am
I am in Georgia. I have a block that has some parts left I was going to offer but you are kinda far for it.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon Jun 17, 2013 8:43 am
Are you the guy with the yellow truck on dodge talk with the bent frame? If so you are having some seriously bad luck :( ........................
crossthreads are better than locktite
PostPosted: Mon Jun 17, 2013 8:54 am
Ah, thanks anyway man.
And yep...that'd be me haha. My truck just doesn't want to live again.
PostPosted: Mon Jun 17, 2013 3:23 pm
We're going to attempt to weld it. My dad is confident he can do it.
Worth a try since it doesn't cost anything and I'm out the block if I don't try.
Ill let you guys know how it goes.
We cut a notch along the crack to fill with weld and clamped it together. We were about to heat it before welding but we ran out if acetylene so it'll have to wait til next weekend.
PostPosted: Mon Jun 17, 2013 4:23 pm
It would be my guess that to have any chance of success you will need a deeper notch and wider V shaped groove to get the strength your going to need.
Just one knuckleheads opinion.
Rick
PostPosted: Mon Jun 17, 2013 4:34 pm
Yeah, good idea. We'll try to give a big more space for the weld to bridge.
 Post subject: It's...
PostPosted: Mon Jun 17, 2013 4:48 pm
We'll try to give a bit more space for the weld to bridge.
Not so much to bridge, but to keep the smaller piece of metal from expanding and goofing up your alignment when you heat it all up and start in with the rod.
Since mopar blockas are high in nickel content, is your dad going to use Ni-rod for the repair?
PostPosted: Mon Jun 17, 2013 5:17 pm
don't want to be the bearer of bad news,, but you have a few things going aginst you
1) I have never seen grey iron castings welded successfully without a pre and post heat process. The pre heat is a heat soak of 900 to 1000 degrees. You will crack it somewhere else...or end up with a twisted block with a ton of stress at that welded bridge.
2) No one with casting - engineering experience would allow weld repairs on a bearing bridge, inside cylinder bores is another no weld area,,,,
3) to stop crack proprogation in grey iron, you will need to drill a round hole, at least the depth on the crack at each end of the crack. Then fill the round holes during the repair process. The round holes act as stress difusers and will prevent the crack from spreading.
again, not wanting to burst your bubble,, but I don't think item 3 will affect you as you won't get by item 1
PostPosted: Mon Jun 17, 2013 5:41 pm
Lemme know when you want a new block.
PostPosted: Mon Jun 17, 2013 6:04 pm
I'm already pessimistic about it, you're not bursting any bubbles.
Every block I've found is a long drive away and will cost me a lot in fuel so it can't hurt to try.
I am aware of the pre and post heat process, my neighbour used to be a welder.
We'll see what happens...I know I can't get it up to the temp it is supposed to be at but it doesn't hurt to try at this point.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
