| New Intake ...sort of.... https://slantsix.org/forum/viewtopic.php?t=52540 |
| Author: | wvenable [ Fri Jun 28, 2013 7:39 am ] |
| Post subject: | New Intake ...sort of.... |
Was messin' on the computer this morning and decided to go to the Clifford website - Why? Don't know! Here is what I found. http://www.cliffordperformance.net/Merc ... ry_Code=MY |
| Author: | DusterIdiot [ Fri Jun 28, 2013 7:48 am ] |
| Post subject: | Old News |
The redline dual weber has been covered years back... it's just a dual 1 barrel manifold opened up to mount dual webers... The pain of it was they offered the kit with dual non-progressive webers (think 4 barrels that open at the same rate...), some issues arose on the time it took to tune the setup to be synch'd right, gas mileage was OK if dialed in right, but with all the tuning issues and the price of the setup the original seller went out of business... I think if there had been more R&D and tuning done before they went to market and been offered with progressive carbs these would have been a good 'car show eye-popping option' for most users. You can search for posts by 66Dart and Doc as they both installed and used them. -D.Idiot |
| Author: | Rob Simmons [ Fri Jun 28, 2013 8:06 am ] |
| Post subject: | Re: New Intake ...sort of.... |
Quote: Was messin' on the computer this morning and decided to go to the Clifford website - Why? Don't know!
Quit daydreamin' about them silly parts what you ain't gots and git ta work on the parts you do gots! |
| Author: | sandy in BC [ Fri Jun 28, 2013 8:32 am ] |
Quote: git ta work on the parts you do gots!
<snork!>
| Author: | wvenable [ Fri Jun 28, 2013 8:46 am ] |
Quote: Quote: Was messin' on the computer this morning and decided to go to the Clifford website - Why? Don't know!
Quit daydreamin' about them silly parts what you ain't gots and git ta work on the parts you do gots! Huh? What did ya say? I was busy daydreaming. Or maybe Cali Dreamin'. http://www.youtube.com/watch?v=N-aK6JnyFmk |
| Author: | slantzilla [ Fri Jun 28, 2013 9:57 am ] |
What a senseless waste of human life. |
| Author: | wvenable [ Fri Jun 28, 2013 12:06 pm ] |
| Post subject: | Re: Old News |
Quote: The redline dual weber has been covered years back... it's just a dual 1 barrel manifold opened up to mount dual webers... -D.Idiot This Clifford piece looks like a new casting purposely made for the two webers not a reworked Offy like this.... http://www.piercemanifolds.com/ProductD ... Code=K9115 That is why is said "new - sort of" - anyway back to the garage 'fore I haveta get an internet restraining order 'gainst the Mater. |
| Author: | SlantSteve [ Fri Jun 28, 2013 4:49 pm ] |
They are the 32/36 progressive carbs in the pic. It claims its a new product!! I reckon those float bowls would get toasty hot , hot starting might be lots of fun. |
| Author: | DusterIdiot [ Fri Jun 28, 2013 5:29 pm ] |
| Post subject: | Yep... |
Quote: hot starting might be lots of fun.
That was another issue now that I come to think of it, the carbs tended to boil out, so a heat sheild and an isolation gasket was needed....(i.e. phenolic spacer or an old school wood one was helpful...). The rear carb was the worst since the airflow in the A-body engine compartment tends to stagnate near the firewall and master cylinder...-D.Idiot |
| Author: | SlantSteve [ Sat Jun 29, 2013 4:29 am ] |
If you could fit a pair of DFEV carbs ( the mirror image of the ones in the pic) the float bowls would be facing out wards ,the linkage may be tricky,but the heat issue may be better??? |
