It is currently Fri Nov 27, 2026 8:19 pm
PostPosted: Thu Jun 27, 2013 11:18 am
Had it rebuilt but when I first start it up she smokes and runs rough until she warms up and runs good .Any thoughtsso I can go back to person who rebuilt it.
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Thu Jun 27, 2013 12:05 pm
Too much fuel.....
If the choke is set correctly.........see the manual which are free downloads under Engine FAQ.
1. Check the float height
2. Make sure the power valve ball isn't being depressed at idle. Sometimes it can get stuck of jammed.....or pop put. If it popped out put the ball and spring back in and push the retainer back in and lock it by slightly indexing the edge so it stays put. You can index/swage/punch the body with a punch or blunt screw driver blade and hammer. You don't have to tap it too hard......the body is pretty soft.
PostPosted: Fri Jun 28, 2013 10:10 am
Thanks Ted
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
