Has anyone ever let their slant idle for 1 hour
https://slantsix.org/forum/viewtopic.php?t=52548
Page 1 of 2
Author:  USAJon [ Fri Jun 28, 2013 6:15 pm ]
Post subject:  Has anyone ever let their slant idle for 1 hour
The drool tube engine in our 1973 Dodge Dart Sport used a little over 1/2 gallon gas, thermostat never opened, hood up, 80's temp weather. Stock idle.
Pure amazement for us.
The thermostat does work also.
Engine looks rebuilt or new if that is possible.
66K miles aprox. on title from auction house verified.
If I can not repair body damage it will be a pickup...ruff one but a driver none the less.
Author:  Old6rodder [ Fri Jun 28, 2013 6:28 pm ]
We routinely run the animation slant on our Rose Parade float at a high (850) idle for extended periods of well over an hour for road tests and during staging, and at low (1850) governed speeds for several hours during parades.
Never has let us down. 8)
Author:  Aggressive Ted [ Mon Jul 01, 2013 10:31 pm ]
Every night routine during summertime rush hour on hot pavement over the last ten years......generally takes 3 hours and sometimes more to get home.
Author:  USAJon [ Tue Jul 02, 2013 3:00 am ]
well you know that running without opening the thermostat for over an hour translates to a very efficient design motor as far as thermal displacement is concerned. Not only long stroke , small bore but internal piston placement /head design/slant configuration to allow radiant head to rise across the whole out side length of the engine rather then a towering inferno cooking the oil in the head like a frying pan on the stove. This design has a signature awaiting discovery....my idle was probably 700-850 by sound, no discernible stress from heat at all. Was this engine with it's forged crank designed for work other then automobile use originally ?
What was Dodge's quest ? Did they design an engine that was beyond their conception . A signature in that design that awaits true interpretation as a MPG killer ! Low RPM torque/excellent thermal ventilation/forged internals....
Author:  DusterIdiot [ Tue Jul 02, 2013 7:39 am ]
Post subject:  But...
It just means that the cooling system is operating more efficiently than the engine creating heat (I'd bet that it's passages aren't a clogged full of rust as most old engines are). The problem that exists in this regard is bore wear, automotive engineers have already charted data showing that engines that are below a certain operating temperature range that bore wear goes up signifigantly...so the startup/fast idle setup is there to get the engine warmed up to operating temp ASAP 1) for economy during driving 2) reduce wear on the bore/rings.
-D. Idiot
Author:  USAJon [ Tue Jul 02, 2013 8:13 am ]
Post subject:  Re: But...
It just means that the cooling system is operating more efficiently than the engine creating heat (I'd bet that it's passages aren't a clogged full of rust as most old engines are). The problem that exists in this regard is bore wear, automotive engineers have already charted data showing that engines that are below a certain operating temperature range that bore wear goes up significantly...so the startup/fast idle setup is there to get the engine warmed up to operating temp ASAP 1) for economy during driving 2) reduce wear on the bore/rings.
-D. Idiot
I would like to see any data on engine operating temperature /cylinder wear.
Where could a guy find that?
When I check out my turbo diesel Jetta engine in our VW caddy. I dropped the oil pan and saw the squinters to the cylinder walls to help cool the engine..this was turbo only app. I was surprised as I did not know they were there.
Author:  Doc [ Tue Jul 02, 2013 8:17 am ]
... Did they design an engine that was beyond their conception ...
Actually, they designed an engine that was intended to be build into a die-cast aluminum cylinder block... the cast iron block was "plan B".
So when Chrysler went with "plan B", we ended-up with a super strong engine block, for the given level of displacement and performance.
Author:  DusterIdiot [ Tue Jul 02, 2013 8:44 am ]
Post subject:  Here's one...
There are a few discussions online and some SAE papers that cover this (pay to view though). Some of this is also covered by David Vizard in his "How to build horsepower Vol.1 & 2".
Just doing a single 1 hour test isn't going to kill things, but if you decided to do it on a regular basis then things will start to loosen up.
-D.idiot
Author:  USAJon [ Tue Jul 02, 2013 9:25 am ]
Well, that's not exactly how it was.
Just got of the phone with Willem Weertman (http://www.allpar.com/corporate/bios/we ... chron.html), age 86 living in a retirement community.
He stated that American Motors had come out with a 6 cylinder aluminum motor and Chrysler wanted to pursue this direction. Early stage 1st design was both aluminum and cast iron. They had a production deadline and that their machinists were not 100% confident with aluminum and went with cast iron for volume production, as that was what they (Chrysler machinists) knew. In 2.5 years, 50,000 aluminum engines were produced. They also went with forged cranks as the norm then. And mechanical lifters were normal and cheap in the total engine cost. Hydraulics came in later for emissions.
Mr. Weertman stated that a four valve per cylinder head and variable camshaft timing is needed for better mpg.
He owns and drives a 2001 Chrysler Voyager, but says it's to large for his current needs.Gets 22 mpg hwy.
A very interesting phone conversation and sharp mind too. He also stated his son ? has a Prius and he has been a passenger in it and states it as a wonderful ride, quiet, powerful, xellent mpg.
Author:  DusterIdiot [ Tue Jul 02, 2013 9:51 am ]
Post subject:  Lol...
has a Prius and he has been a passenger in it and states it as a wonderful ride/quiet/powerful/xellent mpg.
It must be a new gen version, I worked for a company that had the first and second gen Prius as company cars and they were woefully slow to accelerate compared to a normal 4 cylinder gas burner but got good gas mileage (I logged 49 mpg on long trips), their handling also left lots to be desired. Comparatively the company also had 2 honda hybrids and on long distance trips (4 hours straight shot on I-5 south), they got 41.2 mpg with an average cruise speed of 75 in varied Hwy environments (two mountain passes on this drive), acceleration was much like a 4 cylinder civic and handling was very good...comparatively I drove that same stretch of I-5 in the hyperpak duster and logged about 21-23 mpg with the OD tranny and a holley 390.
One side effect of the hybrid though is the battery size and Firefighters in our area have been fined by OSHA for affecting a rescue on people trapped hybrid cars that took front end damage with a totalled or leaking battery without containing the mess first. :roll:
Author:  Aggressive Ted [ Tue Jul 02, 2013 10:48 pm ]
USAJon,
DI's comment....so the startup/fast idle setup is there to get the engine warmed up to operating temp ASAP 1) for economy during driving 2) reduce wear on the bore/rings.
Doing the electric fan conversion helps a lot on warm ups.....I really like my two 10" fans since the thermostat will open about a mile from the house in the morning since there is no fan blowing.....quicker warm ups and less wear!
Author:  64ragtop [ Wed Jul 03, 2013 9:34 pm ]
Post subject:  Re: Lol...
.... Firefighters in our area have been fined by OSHA for affecting a rescue on people trapped hybrid cars that took front end damage with a totalled or leaking battery without containing the mess first. :roll: -D.Idiot
I had to go back and read that again!! Our good friends at OSHA would have the first responders let injured folks wait to be helped until the battery juice is "contained".
Well, I guess that's better than waiting 'til the mess was removed.
I sure hope nobody gets burned alive or bleeds out while the environment is being safeguarded. I'll grant good intentions for wanting to control the battery juice, but PEOPLE FIRST!!!
BC
Author:  DadTruck [ Thu Jul 04, 2013 1:05 pm ]
the 'squiters' are actually 'piston cooling jets' common on all modern diesels..
there to keep the piston from destructing,, not for cooling the cylinder block.
for aluminum diesel pistons,, up to 18 to 1 compression,,in a light duty use like your diesel Jetta,, its the only way they will live, move the same compression up to meduim diesel engine use and you will see gallery cooled pistons, where the piston cooling nozzel shoots engine oil into a cavity cast within the aluminum piston via a salt core...
move up another level to HD (class 8 over the road) diesel engines,, there you will find forged steel pistons with gallery cooling via a piston cooling nozzel...
as far as a gas IC engine running an hour without the thermo opening
either
1) you are mistaken
2) the thermo is stuck
3) cool / cold conditions
4) all have very little to do with engine design parameters unless the motor was designed to run without a thermostst or radiator,, which in the case of the slant six motor,,, it was not.
regards
DT
Author:  USAJon [ Sat Jul 06, 2013 8:34 pm ]
either
1) you are mistaken
regards
DT[/quote]
demo derby no run rads every since/loop with a rad blow off "T"
looped trans lines also/heater blowing all the time / 2 quarts over in oil pan
synthetic ...
I'm not going to maybe hurt our engine to make a point.
it has 66 K on the title/speedo. the engine is a drool tube and looks new.
hope to buy some harbor freight hydraulic body tools and make body right.
[img=http://imageshack.us/scaled/medium/833/delawarelife011.jpg]
Author:  DusterIdiot [ Sat Jul 06, 2013 9:29 pm ]
Post subject:  Splain?
synthetic ...
Can you retype it slowly and explain what I think you're trying to say?
I drove demo derby in my area for 5 years and no heats were ever longer than 5-7 minutes...the only two times that heats lasted longer were: Bash to the last (aka last car standing- runs about 15 minutes to get down to the last sandbaggers and the gran tiger tanks), and car football (teams depend on participants left to play, typically 2-3 cars per team), objective push "the ball-aka a welded up VW bug painted brown" between two 55 gallon drums on each end of the field, winners will have the highest amount of field goals at the end of 15 minutes...if a team member's car dies and you have another team member that can sub, sub will occur when the ball is rest after a field goal....if no other subs it becomes them against you...
Only over heated after I shut the engine off after the bash to the last, and I don't run a T-stat...
One of my teammates came from arizona and ran X track derby, they run rads but no T-stats and are allowed to replace the rad with a water heater behind the drivers seat if 'sheilded'.
Page 1 of 2 All times are UTC-08:00
