It is currently Fri Nov 27, 2026 8:52 am
 Post subject: Holley 1920
PostPosted: Sat Jun 29, 2013 12:48 pm
I am currently rebuilding my 225. It is 30 over and about 9.5 to 1 compression. Comp Cams is grinding me a cam. Can I use my 1 barrel?
 Post subject: Yes, but...
PostPosted: Sat Jun 29, 2013 1:08 pm
Yes, you could using one of comps smaller cams like the 252 or 264, but you will limit your available power by choking off the engine's breathing. a 9.5:1 engine with a comp 252 mech lifter engine will work more efficiently with a stock super six and will develop it's maximum potential with a 390 cfm holley or 500 cfm edelbrock set up for use with a milder engine (making the assumption that the cam is degreed in properly and set with some advance for low end torque for street use and mileage).
Just for reference the 1920 will be about 170 cfm of flow, the BBD will be close to 280 cfm, a small Holley 2300 is 350 cfm, and correcting for 2 barrel flow with the holley 390 so we have apples to apples the small 4 barrel will flow almost the same as 552 cfm of 2 barrel (but not have the vacuum drop of the big 2 barrel having progressive and vacuum controlled smaller barrels).
So if on a budget, you can start with your Holley 1920, it may need to be rejetted to provide better main fueling since the efficiency of the engine will now be greatly improved (would use a Holley #57 jet as a start and #58 as the max size for the carb ). Later when you can afford it moving up to an offy and a 500 cfm AVS would be a good daily driving move all around considering the price and availability of super six manifolds and setups.
