What is this block from?
https://slantsix.org/forum/viewtopic.php?t=52550
Author:  Chuck [ Fri Jun 28, 2013 11:23 pm ]
Post subject:  What is this block from?
I dug this block out of a garage of a friend who passed away, and I have never seen one like this.
1) There is no protrusion in the alternator mounting area with the engine info, but there is a stud inserted.
2) The ribs under the freeze plugs are different from the other 5-freeze plug blocks, and there are 2 horizontal raised areas above the holes. The dip stick tube hole is blocked off with what looks like a threaded plug.
Here is a close-up of the numbers on the side.
What are the square indentations in the casting?
Author:  ceej [ Sat Jun 29, 2013 4:54 am ]
I suspect that you have a Marine engine there. I don't know.
CJ
Author:  Chuck [ Sat Jun 29, 2013 8:34 am ]
It looked that way to me too. Note the brass freeze plugs.
