| Update on ticking/knocking https://slantsix.org/forum/viewtopic.php?t=52554 |
Page 1 of 3 |
| Author: | ILMopars [ Sat Jun 29, 2013 7:06 am ] |
| Post subject: | Update on ticking/knocking |
My engine still makes the noise I told you guys about. It only does it when warm. It matches the rocker arms moving up and down on top of the head. It has not gotten worse, but has not gotten better. It never happens until the temp gauge is off the C and up to the first mark on the bracket on the gauge. Bent puhrod? one rocker not adjusted? |
| Author: | ValiantBoyWonder [ Sun Jun 30, 2013 10:35 am ] |
i'd suggest adjusting the valve lash. do it hot, and do it with the car running. check to make sure all the push rods and spinning and while you're in there make sure they're straight. before you touch anything, with the valve cover off, using a hose to listen to see which rocker is making noise, just be careful, nobody like heater hose in jammed into their ear. Since this only happens with the car hot, i'm betting on the valve lash being off. |
| Author: | slantsik [ Sun Jun 30, 2013 8:35 pm ] |
| Post subject: | Damn ,thought you beat this one. |
OK, as the boy wonder says ,valve lash first. If you find one or two adjusters are at their limit suspect a worn cam and lifters on those cam lobes. I had a similar problem where a noise only occurred after warm up, a metallic clunk clunk at idle only. Turned out to be a worn cam lobe and lifter . dont forget to check those flex plate bolts. do the rod knock test I described in the post from the other week. http://www.slantsix.org/forum/viewtopic ... sc&start=0 A mechanics stethescope is a cheap handy tool. listen for lifter noise at the side of the block about level with the fuel pump bracket. Also check to see if the push rods are all spinning. if one is not that means the lifter is not spinning in its bore ,this will cause the lifter/cam lobe to wear badly. good luck ,hopefully its just an adjustment. Brendan. |
| Author: | ILMopars [ Mon Jul 01, 2013 2:04 pm ] |
Sorry if I bring this up. I am not trying to beat a dead horse. I just have a tight schedule and barely have time to brush my teeth sometimes. |
| Author: | slantsik [ Mon Jul 01, 2013 6:09 pm ] |
lol, I meant I thought you beat the problem,not beat the dead horse, |
| Author: | Aggressive Ted [ Mon Jul 01, 2013 10:09 pm ] |
It only takes about 15 minutes to go through and check them hot. I go about 5 minutes per round if your a perfectionist....and recheck two more times, 3 rounds times 5 min equals 15 minutes. Pulling the cover and replacing it takes 3 minutes if you used a rubber or the pure silicone red valve cover gasket and glued it to the valve cover. I would lash it a .012 and .022. Then you can see if all the push rods are spinning or if any are bent. Get used to checking the lash every year. |
| Author: | 63dartdude [ Tue Jul 02, 2013 9:43 am ] |
http://s303.photobucket.com/user/bttfma ... 3.mp4.html What about 7 seconds into this video? Sounds like something bouncing around inside. This propped up a few months ago, and went away. And then suddenly it appeared again. Any clues out there? |
| Author: | DusterIdiot [ Tue Jul 02, 2013 10:14 am ] |
| Post subject: | Yikes... |
Quote: What about 7 seconds into this video? Sounds like something bouncing around inside. This propped up a few months ago, and went away. And then suddenly it appeared again. Any clues out there?
Tough to say in the video since the pickup is so generalized, I've heard that sound from a failing water pump, to the flap in the stock exhaust manifold not being held by the spring and being buffetted around. If you use a mechanics stethoscope and hear it in a specific cylinder, you may be taking the head off and looking for something that is too big to get stuffed out the exhaust valve and if it's a nut or ball bearing it's doing wonders for your piston...-D.Idiot |
| Author: | 63dartdude [ Tue Jul 02, 2013 10:48 am ] |
I removed all the spark plugs, and they are fine, so I don't believe anything is floating on top the cylinder. Been there before, and found a screw was taking out my spark plugs. I got under the car this morning, and hear the noise coming from the general area of the 4, 5, or 6 cylinder, at head level. Nothing near the water pump. |
Oh yeah, running headers, not the flap. |
| Author: | ILMopars [ Tue Jul 02, 2013 4:08 pm ] |
I'll make a video right now, but I have no idea how long it will take to upload since I have not used all the features on my new computer. |
| Author: | Aggressive Ted [ Tue Jul 02, 2013 10:41 pm ] |
63dartdude, Sounds like a nut or keeper bouncing around inside the valve spring. Hopefully, there is nothing broken and sucked into a cylinder. No small screws missing from the butterfly of the carb? |
| Author: | 63dartdude [ Wed Jul 03, 2013 5:08 pm ] |
Plan to take off the head soon. Have examined the springs, and all looks okay, but will double and triple check that. The rocker arms are moving like they should. Thanks. |
| Author: | ILMopars [ Thu Jul 11, 2013 5:24 pm ] |
It's so weird, I started up the car this afternoon and the thing quit making the noise all of a sudden, like nothing was every wrong... |
| Author: | olafla [ Fri Jul 12, 2013 6:00 am ] |
If you talk softly to the SL6 while stroking the valve cover gently, it somtimes do what you ask for... Olaf |
| Page 1 of 3 | All times are UTC-08:00 |
