It is currently Fri Nov 27, 2026 6:11 am
 Post subject: carb to kickdown linkage
PostPosted: Wed Jun 26, 2013 1:46 pm
Anyone have a good pic of how to hookup a lokar style linkage to the carb?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Sat Jun 29, 2013 9:27 pm
How does this look?
Just to be sure the spring should pull the lever back towards the rear end and the carb should pull it towards the bell housing. Mine in resting position is held towards the rear end.
I took 2 angle brackets and attached the upper one to the hole where the springs attach.
The lower is attached to where the accelerator cable locks in.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sat Jun 29, 2013 10:52 pm
6 Pack Dart
If that is for the transmission down shift you got it backwards. The throttle should pull the lever on the transmission towards the rear of the car, and the spring should pull that same lever to the front of the car.
Richard
PostPosted: Sat Jun 29, 2013 11:03 pm
I am sorry fopar you are right and that is how I hooked it up.
My only other question is when setting the tension should I pull the cable to have "zero lash". This would mean as I hit the accelerator the kickdown will mirror the movement.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Sun Jun 30, 2013 8:50 am
6 Pack Dart
Adjust so when full throtle you have kick down, may have to play with it for proper up shifts.
Richard
Users browsing this forum: Bing [Bot] and 31 guests
