| Ready to throw something - did I ruin my pump? https://slantsix.org/forum/viewtopic.php?t=52558 |
Page 1 of 2 |
| Author: | sandy in BC [ Sat Jun 29, 2013 2:45 pm ] |
Jeez Evan.....you buggerd the pump! Calm down ( my I suggest a nice IPA in a 1 litre bottle) and ask Doug Dutra to send you a good pump with gear. You wont be disappointed. |
| Author: | Fopar [ Sat Jun 29, 2013 3:13 pm ] |
That is good sound advice Sandy, when are you going to bring the beer truck down to Eugene. Richard |
| Author: | Eatkinson [ Sat Jun 29, 2013 4:04 pm ] |
Ahead of you Sandy, I'm downing a cold one. Unless someone tells me 'don't', I'm using this thing regardless. Pump seems to be fine, damage is there, but doesn't seem consequential. Pump is in the freezer now. Then I will heat the hardened gear DD sent, and slip it on. I still can't believe I did that. And more, I can't believe that Melling makes a pump without a keyway that extends the full shaft length and then has the nerve to weld in a key. The NERVE, I say!!! |
| Author: | Fopar [ Sat Jun 29, 2013 4:14 pm ] |
I would not use the pump, it is broke get a pump from Doc. A motor is not cheep to rebuild. Richard |
| Author: | emsvitil [ Sat Jun 29, 2013 4:14 pm ] |
I'd be tempted to just shorten that part of the pump to get rid of the cracked area............. |
| Author: | Fopar [ Sat Jun 29, 2013 4:17 pm ] |
That isn't a good idea, get another pump! Richard |
| Author: | DusterIdiot [ Sat Jun 29, 2013 4:22 pm ] |
| Post subject: | Don't |
Quote: Unless someone tells me 'don't', I'm using this thing regardless. Pump seems to be fine, damage is there, but doesn't seem consequential. Pump is in the freezer now. Then I will heat the hardened gear DD sent, and slip it on.
That's the 'load' end of the pump since the torque is going to bear on the gear and end of the shaft, and the gear will be riding against the cracked housing as well as is moves against the rotation of the cam gear, unless you can weld it up and make it good again it's going to be a problem down the road (worst case scenario there is enough shaft/rotor play and the gear comes out of alignment and mis-meshes against the cam gear and you end up replacing both...)The drift punch idea works some of the time...(not 100%) Get a DD special and keep the guts/parts of this one for a future fixit down the road. If you were in Oregon I'd tell you that a growlette of Ninkasi Tripel will solve the issue and any stress you are having now.... -D.Idiot |
| Author: | Fopar [ Sat Jun 29, 2013 4:27 pm ] |
I'll drink to that D.I. Richard |
| Author: | slantzilla [ Sat Jun 29, 2013 5:47 pm ] |
That pump is a paperweight. Get a new one. |
| Author: | slantzilla [ Sat Jun 29, 2013 5:48 pm ] |
| Author: | Eatkinson [ Sat Jun 29, 2013 8:11 pm ] |
| Post subject: | Re: Don't |
Quote: Keep the guts/parts of this one for a future fixit down the road.
Great. Back to square one. I possess another new Melling pump that's the 5 bolt, not the 6 (wanted the 6 for any potential leakage issues: kiss that idea goodbye, dammit), but it too has the soft gear on it that I must swap out for the DD hardened one. What a stupid waste.-D.Idiot I guess I'm have to open up the Posi-Lock puller. |
| Author: | Dart270 [ Sat Jun 29, 2013 8:22 pm ] |
My advice: That one is junk. Use your original pump with no modifications except to put a thin (~0.060") washer under the spring in the relief valve. I have used two well used bone stock high on high perf motors with no problems. Lou |
| Author: | DusterIdiot [ Sat Jun 29, 2013 8:43 pm ] |
| Post subject: | Lol... |
Quote: Use your original pump with no modifications except to put a thin (~0.060") washer under the spring in the relief valve. I have used two well used bone stock high on high perf motors with no problems.
Shhhh...don't tell him all the secrets Lou! (I actually have one like this in the motor in my brown duster.) I put a #10 nut that's about 3/16" thick under the spring-between it and the cap, and it oils really good with no problems...pretty good for a 1970's over 100-200K oil pump.... -D.Idiot |
| Author: | Eatkinson [ Sat Jun 29, 2013 9:01 pm ] |
Quote: My advice: That one is junk. Use your original pump with no modifications except to put a thin (~0.060") washer under the spring in the relief valve. I have used two well used bone stock high on high perf motors with no problems.
Lou, thanks for the tip but I don't have an 'original' pump to use anymore. What pump are you calling junk, my cracked neck pump? So you're telling me to do the washer trick on the new 5-bolt Melling? My 'original' pump out of the car was the Chrysler-made aluminum-bodied pump that I destroyed trying to remove (it was basically glued to the block and refused to let go). I found this used 6-bolt Melling and was trying to rehab/use this pump and keep the new Melling to either use somewhere else or return, but now that plan's shot: I have to use it. Will your trick work on this new one, or does it need it?
Lou |
| Page 1 of 2 | All times are UTC-08:00 |
