Really new to this - need advice
https://slantsix.org/forum/viewtopic.php?t=52559
Author:  Nabby [ Sat Jun 29, 2013 3:01 pm ]
Post subject:  Really new to this - need advice
I have a 77 Volare Wagon sitting in my garage that's been there for a couple years now. It used to be my daily driver until the front suspension bit the dust. Now I've got a friend with a shop and I'm thinking of rebuilding the 225 on it and getting all the suspension redone while the engine is out. For as long as I drove it, it was painfully slow, though. I'd like to get a little more oomph from it, but I'm not sure where to go with it and I'd like some advice. I'm thinking of buying the aussiespeed 4bbl carb type intake with spots for injectors to be drilled, and I saw over on jegs the EZ-EFI that has pretty much everything I need for EFI on a 4150 style intake. http://www.fuelairspark.com/fas/ez-efir ... r-kit.html
As far as the engine itself, I'm at a loss... perhaps the overbore of .045 or .104 to get more piston options and use the piston rods off the 198 for longer stroke as per Doug Dutra's "long stroke". Not sure which pistons to use though, so I'm definitely open to suggestions. The biggest question I have, is if I overbore, do I need bigger gaskets, and if so, where do I get them? And should I do anything extra with the cam and valves to get more power out of this setup?
Author:  Joshie225 [ Sat Jun 29, 2013 3:16 pm ]
Hopefully your car isn't too rusty. In your neck of the woods rust can do a lot of damage to suspension mounting pints and structures.
You do not have to buy a lot of special parts to substantially improve your car's acceleration. With the Super Six package, free flowing exhaust, a little head work to increase flow and compression ratio, well tuned fuel delivery and ignition you can get quite good performance. What kills most of these cars for performance is low compression, weak mixture and late timing. The axle ratio may also be a big hindrance.
Author:  ceej [ Sat Jun 29, 2013 3:20 pm ]
None of the plug and play EFI systems are really plug and play.
EZ-EFI won't be easy. :roll:
I chose not to pursue EFI because I have enough hobbies. :lol:
CJ
Author:  DusterIdiot [ Sat Jun 29, 2013 4:33 pm ]
Post subject:  X2
Without having to go down the exotic road, you can get very good performance out of a standard rebuild kit and judicious selection of
the right cam for the job and save loads of $$$ for something else.
Like Josh said, a little attention to the details will make things work great, the skunky highway rear ratio and the heavy car will need a kinder ratio to make it all work together better.
I would also Second Ceej's opinion of EFI, nothing is plug and play, most people will build the engine, break it in with a carb, then make the swap to EFI so they can iron out the basic bugs of the model of EFI they are working on. I would not spend $2200 on an EFI system unless I had a complete grasp of programming the fuel tables and a good grasp of how the engine likes timing (especially on a new motor that will not react like a stock slug). Rebuild it for a 9.5:1 SCR with a RV/Torque cam, change the rear ratio to 3.23's, and run a 2 or small 4 barrel carb (also you'll have to recurve the distributor to get the most out of it too...and understand how to program the timing map in the EFI software if you go to a crank trigger/computer controlled timing).
Truth be told I spent quite a few evenings in a warzone programming fuel maps and timing maps for a specific build and those are just a rough-in...
