It is currently Fri Nov 27, 2026 4:24 am
PostPosted: Sun Jun 30, 2013 10:53 am
As asked above
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
 Post subject: What parts?
PostPosted: Sun Jun 30, 2013 11:35 am
I expect the block, rods, etc. with hot tank and magnaflux to be in the $500-700 range depending on how much work is to be done (overbore/deck milling), that doesn't include crankwork if needed, rod bolts, and master rebuild kits. The head if starting from a complete core with new exhaust seats, o/s valves to be another $500 (you provide the valves/springs/locks/retainers).
PostPosted: Sun Jun 30, 2013 2:40 pm
I recently paid 1500 for COMPLETE rebuild including cutting for larger valves, -.010 on the crankshaft, milling the head and block, rebuilding the pistons, .040 over bore of the cylinders and bottom end assembly.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon Jul 01, 2013 11:11 am
Car Model: 1964 Valiant V200
I will be paying about $300 for block hot tank, bore, hone with deck plate, new cam bearings and check deck height.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], DuckDuckGo [Bot] and 1 guest
