It is currently Fri Nov 27, 2026 5:36 am
 Post subject: Exhaust Valves
PostPosted: Sat Jun 29, 2013 11:23 am
was doing some reading and saw that Chrysler Flathead Six made after 45 or so had Sodium Cooled Exhaust Valves. Seems like a good idea, anybody have input on this? are there some Sodium Exhaust Valves out there for a slant?
70 Plymouth Valiant 4dr
 Post subject: Nope...
PostPosted: Sat Jun 29, 2013 12:08 pm
The Hemi also used a similar valve in some applications, don't think anyone has gone that route since our engine wasn't exactly primed to be a contender in the muscle wars of the late 60's. I don't see it as being beneficial over the cost of the install in our applications at this time, if we have exhaust temp problems that are causing an issue of overheating the exhaust valves then the use of a richer mix from the carb is warranted in a race engine, and in daily driving the use of an EGR might prove helpful.
I can see this as being something that will be in newer EFI vehicles where the stoich is typically 18-22:1 to provide better emissions and that can raise the temp and put some abuse on the exhaust valve.The manufacturer then put the NOX output back in the box by adding lots of EGR as well...
2 cents...
PostPosted: Sat Jun 29, 2013 2:32 pm
The chryco flathead sixes were a valve in block design that suffered from chronic heat issues. We are talking about a motor that needed a valve job (in the block .....in the car ) at 40 000 mile intervals. They were desperate for some solutions.....one was sodium filled exhaust valves.....another was a really pricey hemi V8.
...a cheaper solution turned out to be a little six with valves in head .....that needed no such expensive or exotic solutions.
I own a couple of flatheads with sodium filled valves....you dont want to go there.
PostPosted: Sat Jun 29, 2013 8:22 pm
You might find some small block Chevy valves if you are going bigger. Sodium filled were used in some hypo stuff and some truck engines.
PostPosted: Sun Jun 30, 2013 10:16 am
Sandy, i work for a guy who has a 49 Plymouth Special Deluxe with the flat 6 in it. he was telling me that the first mechanic work he ever did was when him and his dad took it down to get the valves cut with the engine in the car. i've yet to find an article describing this process. i find it interesting. Know the name of the machine that did this "valve in car cutting?"
