rubber vs. cork gaskets?
https://slantsix.org/forum/viewtopic.php?t=52567
Author:  ddonner [ Sun Jun 30, 2013 9:20 am ]
Post subject:  rubber vs. cork gaskets?
I am curious as to why knowledgeable mechanics might choose one or the other gasket material for a particular job. For instance if a valve cover is expected to be on and off on a regular basis for flat tappet adjustments? If its a grandmother car that won't see anything being taken apart for the next 60K miles? Is there a sealing advantage with one or the other material? Basically a general knowledge kind of question.
Author:  ValiantBoyWonder [ Sun Jun 30, 2013 10:28 am ]
the cork gaskets tend to harden and turn brittle, then when you pull your valve cover off, it leaves schmutz on the head and you have to scrape it all off to get another gasket to seal. i prefer the rubber ones because they tend to be about a dollar more and if you use them right (don't over tighten) you can have that valve cover off and on a number of times and reuse the gasket. if you plan on having something come off and on repeatedly, then i'd suggest either putting a little grease on before the gasket, or just spending the money and buying from these folks http://www.realgaskets.com/files/automobile.htm
Author:  DusterIdiot [ Sun Jun 30, 2013 11:24 am ]
Post subject:  Material cost vs. reusability...
I think to answer the original question:
Cork material was cheap and plentiful in the good old days, and the valve cover gasket was considered an "expendable" for the dealership as part of the package : oil change/tuneup/valve lash...
These are still out there and per the description above are pretty much a one use gasket (maybe 2 if careful and lashing fairly soon after the first installation), and messy to remove unless 100% cooked.
The rubber and silicone ones are better as they can be reused quite a few times before leaking (keeping the mating surfaces free of oil before installing or re-installing goes a long way on this, as well as having a good valve cover lip for good even sealing).
Even on a grandma car slant six you are going to want to check the valve lash a couple of times before 60K. In other sealing surfaces (like the oil pan gasket), it's also an economic item, typically the pan isn't going to be coming off for 100+K miles and the 'gunk' from dirty oil will fill in the space between the pan and engine skirt helping seal it up, so not as critical and Felpro/Victor Reinz will just get the cheaper cork gaskets for those applications.
There are better gaskets out there for most applications but in the case of typical over the counter gasket sets the money to be made vs. frequency of use vs. production cost will set the business model.
on the other hand, some mechanics are loyal or have had a good track record with certain brands or types and will just recommend or use what they know works.
