| What does everyone pay for machine work? https://slantsix.org/forum/viewtopic.php?t=52568 |
| Author: | RyGuyTooDry [ Sun Jun 30, 2013 10:53 am ] |
| Post subject: | What does everyone pay for machine work? |
As asked above |
| Author: | DusterIdiot [ Sun Jun 30, 2013 11:35 am ] |
| Post subject: | What parts? |
I expect the block, rods, etc. with hot tank and magnaflux to be in the $500-700 range depending on how much work is to be done (overbore/deck milling), that doesn't include crankwork if needed, rod bolts, and master rebuild kits. The head if starting from a complete core with new exhaust seats, o/s valves to be another $500 (you provide the valves/springs/locks/retainers). -D.Idiot |
| Author: | jhdeval [ Sun Jun 30, 2013 2:40 pm ] |
I recently paid 1500 for COMPLETE rebuild including cutting for larger valves, -.010 on the crankshaft, milling the head and block, rebuilding the pistons, .040 over bore of the cylinders and bottom end assembly. |
| Author: | robertob [ Mon Jul 01, 2013 11:11 am ] |
I will be paying about $300 for block hot tank, bore, hone with deck plate, new cam bearings and check deck height. |
