Please HELP me with my intake leak
https://slantsix.org/forum/viewtopic.php?t=52573
Page 1 of 1
Author:  Dodge_Dart_340 [ Sun Jun 30, 2013 4:10 pm ]
Post subject:  Please HELP me with my intake leak
Any idea's on why my remflex gasket is leaking in the middle of the head on the intake. I have checked the head and checked the intake with a machinist scale. This is my second remflex gasket the first one did the same thing. I did only torque them to 5-10lbs. I was very careful bolting them down. and follwed the remflex directions.
Author:  ceej [ Sun Jun 30, 2013 4:46 pm ]
What intake are you using? Are you sure this is where the leak is from? Usually, those silly putty intake gaskets will seal just about anything.
5 lb-ft doesn't cut it. 10# is on the edge. I torque to 12 lb-ft. I also use the cheapest over the counter gasket I can find. I don't have problems.
Author:  Kidd [ Sun Jun 30, 2013 5:35 pm ]
I only use remflex. I think you dont have them snugged enough myself.I dont ever torque them either......just tight works for me. :D
Author:  jhdeval [ Sun Jun 30, 2013 6:17 pm ]
I also torque to just tight. I don't grab the end of the wrench and yank I usually just tighten to hand tight trying to keep it consistent across the board. I also use the cheap over the counter and have not had any problems.
Author:  Dodge_Dart_340 [ Sun Jun 30, 2013 6:41 pm ]
So do u just use a stock gasket? cause im using clifford headers and a offenhouser intake. an im not too sure if a stock gasket would work with thos.
Author:  DusterIdiot [ Sun Jun 30, 2013 7:07 pm ]
Post subject:  Did you?
Did you figure out a way to even out the 3/8" mount tabs on the offy vs. the 1/2" flange on the cliffords? That's part of the problem there, you might need to either grind one side of the triangular washer to even the clamping force on both sets of manifolds/headers, or insert a piece of 12 gauge steel to make up the 1/8" difference before tightening them down on the manifold.
