| Carburetor Shop in the Portland Area https://slantsix.org/forum/viewtopic.php?t=52579 |
| Author: | nicholas482109 [ Mon Jul 01, 2013 9:06 am ] |
| Post subject: | Carburetor Shop in the Portland Area |
Does anyone have any reccomendations as to where I can get a throttle shaft rebushed around Portland, OR? I've called about every place that came up in various google searches. All of them have either said the no, guy that used to do that work retired, or quote me at "a few hundred bucks" after a lengthy discussion on whether or not slants came with a 2 barrel carb.. D.Idiot recommended Savas Tuning, just south of Portland, but they much be out of business as I've gotten no answer each time I've called. If there really isn't a place, what about anywhere I can ship it to to get the work done? |
| Author: | Reed [ Mon Jul 01, 2013 9:33 am ] |
These guys are up in Tacoma, but I have dealt with them before and found them to be very helpful and knowledgeable. Plus they have shelves and shelves of cores they let me paw through. http://www.carburetion.com/index.htm Shipping shouldn't be too bad, and if they can't rebush a throttle shaft for you then they can tell you who could. Have you tried a regular old machine shop? |
| Author: | Fopar [ Mon Jul 01, 2013 9:52 am ] |
Machine shop in Junction City did my daughters super six no where near $100. Richard |
| Author: | nicholas482109 [ Mon Jul 01, 2013 10:19 am ] |
Only automotive machine shops. I'm hesitant to bring it to a non-automotive one and have it done poorly. I guess it would be unlikely they would say they can do it if they don't know how. I'll give that shop in a call and see what they can do. |
| Author: | Fopar [ Mon Jul 01, 2013 11:29 am ] |
Car quest 541-998-6882 ask for Gary in machine shop. Richard |
| Author: | robertob [ Mon Jul 01, 2013 12:19 pm ] |
It's actually quite easy to do it youself. You can buy the reamer and bushings on ebay. |
| Author: | nicholas482109 [ Mon Jul 01, 2013 1:16 pm ] |
Quote: It's actually quite easy to do it youself. You can buy the reamer and bushings on ebay.
I'm all for doing it myself but probably won't this time around. What kind of tools would I need for something like that?
| Author: | robertob [ Mon Jul 01, 2013 2:40 pm ] |
Easy way: A special reverse-cut 3/8 reamer. Cheap way: A 3/8 regular reamer with a 5/16 round shaft, which you then modify to have backwards cutting edges with a whetstone. That's it. The 5/16 shaft of the reamer pilots in the opposite side of the bore to center the cutting end. Do the linkage side first (because the other side will provide a more accurate center). It's a handheld procedure. |
| Author: | nicholas482109 [ Mon Jul 01, 2013 4:03 pm ] |
Quote: Easy way: A special reverse-cut 3/8 reamer. Cheap way: A 3/8 regular reamer with a 5/16 round shaft, which you then modify to have backwards cutting edges with a whetstone.
Hmm, so you just use a tap handle and put the reamer in both holes to ensure a centered hole? What about removing and installing the bushings?
| Author: | robertob [ Mon Jul 01, 2013 4:22 pm ] |
The bushings are a light push fit so no tools needed, use loctite on the outside to keep them in place. When you cut the hole don't go all the way into the throttle bore - leave a little bit so the bushing has something to seat against when you push it in. Once you are done file away the protruding bushing on the outside. The throttle plates are held on with brass screws that are peened over on the end - remove them by breaking the heads off and unscrewing out the other side with needlenose pliers. Replace with regular SS screws the same size and blue loctite. I learned how to do it from some british car websites, but people do it to Quadrajets and such too. |
| Author: | nicholas482109 [ Sat Jul 06, 2013 1:08 pm ] |
Could you show me a link to the reamer and bushing on ebay? |
