| oil pump rotor scoring https://slantsix.org/forum/viewtopic.php?t=52581 |
| Author: | robertob [ Mon Jul 01, 2013 11:26 am ] |
| Post subject: | oil pump rotor scoring |
Was planning to use the old pump in my engine build, but the rotors look like the pump ingested a handful of sand. The clearances are good but I'm hesitant to use it because I might end up with low idle oil pressure. |
| Author: | robertob [ Tue Jul 02, 2013 11:38 am ] |
Pump is jump. As much as I want to use it, the scoring is just too bad. New one on the way - I'll swap the gear from the factory pump. |
