It is currently Fri Nov 27, 2026 1:07 am
 Post subject: Offy valve cover
PostPosted: Sun Jun 30, 2013 2:26 pm
My original valve tin had a PCV at the rear and a breather vent at the front.
I switched to an Offy cast cover, and I drilled and fabricated a stack at the back for the PCV. I've had to put an oil catch can due to oil vapor being sucked up through the PCV, I have a good baffle to deflect oil splash well away from the stack but every few thousand miles I get about 100ml of oil in the catch can. Is this normal?
Anyway, I'm thinking of switching to an Offy valve cover that does not have the PCV or any venting at the rear. Is this OK, just to have the breather stack at the front and no PCV? My engine is a '67 225. The crankcase would be ventilated, but is there an air flow issue?
Thanks,
BG
 Post subject: See this post
PostPosted: Sun Jun 30, 2013 3:09 pm
http://www.slantsix.org/forum/viewtopic ... t=breather
 Post subject: Pcv
PostPosted: Sun Jun 30, 2013 6:18 pm
Great, so I have the proper set up and will leave it alone...thanks so much.
bg
PostPosted: Mon Jul 01, 2013 10:26 pm
I run a Jeg's air/oil separator and catch a little oil even in the stock location. I like the SMP V180 PCV the best. You can look at my install pictures of the set up by clicking on the link below my name.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 32 guests
