| Manifold/carb question https://slantsix.org/forum/viewtopic.php?t=52590 |
| Author: | Sawmill slant sixer [ Mon Jul 01, 2013 9:06 pm ] |
| Post subject: | Manifold/carb question |
After setting the timing we have found a major vacuum leak. Grandpa fabricated a plate 20+ years ago to rotate the carb 90* so the linkage was inline with the motor. Its a Carter carb. We don't think there is a gasket there and if there is, its got to be bad by now. My FIL is wondering if there is a "block" that goes between the carb and manifold and what kind of gasket goes there. The motor is a 66' 225 /6. Thanks for any info. |
| Author: | DusterIdiot [ Mon Jul 01, 2013 9:21 pm ] |
| Post subject: | Uggghh... |
My 1972 John Deere intake had a factory carb adaptor on it that rotated the carb 90 degrees so the engine could use the Bendix carb...To bad it's history now, that would have been an upgrade to your setup... The stock carter and Holley 1920 would have the very thin carb gasket, so yes it should have something under there, and if using a custom carb adaptor there should be either a gasket or some RTV at that joint to seal things up. -D.Idiot |
| Author: | robertob [ Mon Jul 01, 2013 10:25 pm ] |
Wouldn't the stock gasket have been one of those 3/8 thick ones? That's what my '64 always had under the Carter. |
| Author: | DusterIdiot [ Tue Jul 02, 2013 7:42 am ] |
| Post subject: | Depends... |
Quote: Wouldn't the stock gasket have been one of those 3/8 thick ones? That's what my '64 always had under the Carter.
Being 20+ years for him, it depends on the carb rebuild kit and what it came with. The last BBS kit I got from BWD had the thin gasket, Holley Kits could come either way. The thicker gasket would be nicer since it keeps the engine from heat soaking the carb.-D.Idiot |
