It is currently Thu Nov 26, 2026 10:13 pm
 Post subject: vacuum readings
PostPosted: Mon Jul 01, 2013 4:19 pm
It's a constant work in progress, getting the valiant running it's best. I took apart the carb, adjusted the float so that it would stop leaking into the throat of the carb at idle. I put it back together and was getting a very noticeable vacuum leak. I figured disturbing the gaskets must have caused it. So, I got a new rebuild Kit, sanded down the surfaces and reassembled with new gaskets.
Seems to be running much better. I have an unknown aftermarket lost cam. Had to set it at 850-900rpm for a smooth idle. I also got a vacuum gauge and was getting about 16.5 psi in park, but 12psi in gear at idle. This is with flickering. Im thinking the low readings and flickering may be related to the cam.
But what do you think? Valve lash is at .010/.020.
Before all this, I got 21mpg highway on a 130 mile trip. HEI ignition, ngk plugs at .045. 2.76 gears.
Anything else you would recommend doing?
69 Plymouth Valiant
PostPosted: Mon Jul 01, 2013 4:27 pm
Loosen the valve lash as much as you can... before it starts to "tick". (try .016 & .025 - go more if you can)
 Post subject: X2
PostPosted: Mon Jul 01, 2013 5:05 pm
If you have an unknown cam, lashing to "stock" settings will not help (and can make things miserable, if the lash was supposed to be even looser).
Basically if you tighten the lash above the spec for the ramp of the cam, the cam will act like it's got more duration (i.e. lopey, lumpy, choppey, etc...).
So it's better to start a little loose than tighten it down (even comp cams say .012 for lash, but seem to run better closer to .014-ish)
Without the cam card you're going to have to loosen the lash while watching the vacuum reading and see if it gets better the looser it gets, but stop per doc's post and/or if you aren't getting anymore beneficial gain in vacuum.
PostPosted: Mon Jul 01, 2013 5:41 pm
Thanks guys. As always, a big help.
69 Plymouth Valiant
PostPosted: Thu Jul 04, 2013 8:42 pm
Follow up:
I adjusted valves to .015/.022
The idle smoothed out a lot and got it to idle at 750rpm in park. Engine doesn't rock on the mounts while in gear, like it used to.
Vacuum readings are 22.5 in park, and 21 in gear. Still a flicker on the gauge, but not as much as before.
No word yet on how this may have effected mileage or power.
69 Plymouth Valiant
Users browsing this forum: No registered users and 24 guests
