It is currently Fri Nov 20, 2026 10:44 am
PostPosted: Thu Jul 04, 2013 5:46 pm
Is the 833OD throw out bearing lever unique to the OD bellhousing? Reason I ask is I was looking at mine tonight and see that the lever is missing.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
 Post subject: Depends...
PostPosted: Thu Jul 04, 2013 6:04 pm
Good but loaded question...
If your bellhousing is a 1981-1987 A-833 OD with the ballstud clutch fork...then yes, only the truck version works and it is a longer fork for use withe the truck/van Z-bar...
The 1975-1980 units with the spring tab retainer (bellhousing has a iron angle with a square hole in it to hold the fork), then no...the late 60's to 1980 3 and 4 speed fork will work (note that the 3 speed fork has a little different configuration on the edges of the fork, but inserts fine and works fine...). The NP435 fork from a truck uses a different TOB and will not work for this application...but in the late 70's some trucks with the NP435 did get the standard A-833 TOB, and the long fork....
Other things to note: Using the longer truck fork has worked for some people but in a pre-67 A-body the installation of the fork may be difficult due to the earlier A-bodies location of the torsion bars....also if you do go that direction, look at the alignment of the fork and Z-bar/actuation rod...if they are at more than a slight angle (15 degrees or more), they may not stay together too long especially in spirited driving.
I have a Z-bar from a 1963-64 3 speed car and it is shorter than the late forks, and has a different actuator rod receiver on it.
PostPosted: Thu Jul 04, 2013 6:13 pm
Thanks for the quick reply. The OD/bellhousing is most likely out of an A/F Body - short tailshaft on the transmission.
Guess I'll start looking for the TOB lever out of a late 60s/80 3 or 4 speed.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
